Main : Misc : Forum Photo of my new TRI-BAR
[<   Previous  212  213  214  215  216  217  218  Next   >]
Photo of my new TRI-BARPopular
SubmittersssuteMore Photos from sssute   Last Update2007/7/16 12:15    Tell a friendTell a friend
Hits2582  Comments11    0.00 (0 votes)0.00 (0 votes)
Just finished a bunch of these.
hotrocket
Posted: 2009/3/18 21:16  Updated: 2009/3/18 21:16
 Re: Photo of my new TRI-BAR
now since you mension that....yes theres still two there, woundering how far the actual rubber go's in
hotrocket
Posted: 2009/3/18 19:37  Updated: 2009/3/18 19:37
with your crank pulley there have you machined off two pulley or you found some thing else that fits?
im looking to get rid of the first pair for more room
PIGDOG
Posted: 2009/3/18 21:08  Updated: 2009/3/18 21:08
thats why theres so much room there, i see now
i was going to do that to my CA crank pulley but it turned out that the pulley bit that you actually use isnt attatched to the harmonic balancer itself, there is a gap between them (or atleast from what i could see) so if you machine the front 2 pulleys off the back one is no longer attatched
edit, loks like you have only taken one off actually....so it could be the stock pulley machined down then i guess
oan878
Posted: 2007/7/16 12:32  Updated: 2007/7/16 12:32
how much?
sssute
Posted: 2007/7/16 12:55  Updated: 2007/7/16 12:55
We are selling them for $260 complete, including end plates, rod ends, pollished ally bar and mounting plate and stainless steel bolts and nyloc nuts.
WhiteSedan
Posted: 2007/7/16 13:11  Updated: 2007/7/16 13:11
Scott, will it not warp the drainage part from hard cornering? My friends 180b rally car the bars went through the firewall and the rod ends bolt to a bracket on the rollcage under the dash.
I still have to get that suspension off my car and bring it down to you so we can measure up those radius rods, the cars in getting the cage this week so I should have it back early next week.
Cheers
Sean
sssute
Posted: 2007/7/16 14:12  Updated: 2007/7/16 14:12
Sean, the bars bolt through the drainage chanel, as well as the firewall, i dont think you will damage it through hard cornering.
About those adjustable caster bars, just give me a call when you are ready, i should be able to sort something out.
Cheers Scott
Mildman
Posted: 2007/7/20 5:49  Updated: 2007/7/20 5:49
Is there any extra drilling required at the firewall to mount those extra bars?
rb20
Posted: 2007/7/20 10:09  Updated: 2007/7/20 10:09
pm sent on urelated matter
sssute
Posted: 2007/7/20 14:00  Updated: 2007/7/20 14:00
No not to the fire wall, you will have to drill two holes through the upper lip.
Scott
Joshh
Posted: 2007/8/2 1:55  Updated: 2007/8/2 1:55
#### that's a tidy install!
campo
Posted: 2007/8/2 2:07  Updated: 2007/8/2 2:07
awsome bar sssute. i was just about to do a search and look for it. have you started selling them yet? can we get another pic, front on?
