Main : Mechanical : Drive Train either A or L series bellhousing?
[<   Previous  621  622  623  624  625  626  627  Next   >]
either A or L series bellhousing?Popular
SubmitterTUF-110More Photos from TUF-110   Last Update2007/7/19 8:21    Tell a friendTell a friend
Hits3451  Comments7    0.00 (0 votes)0.00 (0 votes)
this is a pic of my bell houseing on my gearbox as requested by whitesedan to determin if it is A or L series
L18_B110
Posted: 2007/7/19 8:26  Updated: 2007/7/19 8:26
 Re: either A or L series bellhousing?
definitely not L series.
TUF-110
Posted: 2007/7/19 8:28  Updated: 2007/7/19 8:28
wtf? is it a series then? the guy told me it was l series bastard!
pepper
Posted: 2007/7/19 8:49  Updated: 2007/7/19 8:49
its not an a series either
the starter should be down bottom with clutch up top
TUF-110
Posted: 2007/7/19 8:59  Updated: 2007/7/19 8:59
yer definately not a series i just popped down to the shed and lined the a series plate that goes between the flywheel and block to the boxs bellhousing and the bellhousing is much larger and the starter motor hole in the wrong spot thanks for that pepper
Mildman
Posted: 2007/7/19 9:29  Updated: 2007/7/19 9:29
There's no support for a clutch cable either - so it must by hydraulic clutch.
It's not a CA bellhousing either...they have starter on the top 'driver' side of the bell and the hydraulic clutch lever below the starter - which is sort of like this, but a CA is bigger too
Posted: 2007/7/19 22:12  Updated: 2007/7/19 22:12
Here the A12/A14 pattern (they use the same):
Engine Plate
L18_B110
Posted: 2007/7/19 23:36  Updated: 2007/7/19 23:36
my bad. its L series after looking at my box under the house. in my defence, it does seem to be missing a bolt/dowell hole down the passenger side... but it is L series. Sorry for the confusion.
