Main : Misc : Forum SR20 NA to turbo block mods
[<   Previous  207  208  209  210  211  212  213  Next   >]
SR20 NA to turbo block modsPopular
SubmitterDavemanMore Photos from Daveman   Last Update2007/7/29 4:59    Tell a friendTell a friend
Hits3691  Comments5    0.00 (0 votes)0.00 (0 votes)
for 2Qk4U
kegs
Posted: 2007/7/30 2:16  Updated: 2007/7/30 2:16
 Re: SR20 NA to turbo block mods
Unless you have a stock turbo and lines the only hole you really need is the drain. You can get oil feed from the oil pres, and water from your heater hoses.
you could do it the way you say but using these points makes the lines shorter and the use of proper fittings is permitted.cutting the heater hose to put in a teepiece will most probable cause annoying leaks, like my turbo a15 had.
oan878
Posted: 2007/7/29 6:03  Updated: 2007/7/29 6:03
it this for the wags?
2QK4U
Posted: 2007/7/29 6:09  Updated: 2007/7/29 6:09
nah for my ute
mad120y
Posted: 2007/7/29 17:28  Updated: 2007/7/29 17:28
Check out Here for more info
Daveman
Posted: 2007/7/29 19:28  Updated: 2007/7/29 19:28
Heh looks like we have the same source. Thanks Ders!
