Main : Misc whats this?
[<   Previous  2516  2517  2518  2519  2520  2521  2522  Next   >]
whats this?
whats this?Popular
SubmitterfrankthedolphintrainerMore Photos from frankthedolphintrainer   Last Update2007/8/12 13:12    Tell a friendTell a friend
Hits2193  Comments6    0.00 (0 votes)0.00 (0 votes)
i presume its a surge tank but what are the fuel lines coming of it would the one on the left be a return line and the one on the right of it be feed?
Posted: 2007/8/12 13:14  Updated: 2007/8/12 13:14
 Re: whats this?
and also why is there a link between the surge tank and the fuel tank filler?
i need this info so i can get a return line for my new fuel pump it seems that a weber does not like 100 psi at the float.
PIGDOG
Posted: 2007/8/12 13:16  Updated: 2007/8/12 13:16
 Re: whats this?
i think its for fuel vapors or something....at a guess
just find another ute fuel line and put that in as a return
1200rallycar
Posted: 2007/8/12 13:48  Updated: 2007/8/12 13:48
 Re: whats this?
it's a breather system for the fuel tank, you need to work out how it all works, but you should be able to tap in your return line back into that filler neck
easiest would be to connect to the filler neck and drill a hole in the filler cap as a breather...
depends how dodgey you want to be
actually just remebering how i did it.... if you remove the small panel in the tray of the ute that gives you access to the top of the petrol tank.... you can get at the fuel gauge sender
on the utes the fuel gauge sender doesnt have a breather there (as part of the gauge sender unit) but on the coupes they do
i swapped the fuel gauge sender from the coupe into the ute, then plumbed my return fuel straight down that breather
no problemo..... except..... the coupe fuel gauge sender float arm is half the length so the fuel gauge says empty when the ute tank is only half full
if i had more time i would have cut and shut (it's not a simple swap) the arm off the ute one and the gauge would have worked fine
of course i told myself i'd do that later but still haven't got around to it
anyway hope that makes sense... thats gonna be your easiest way
PIGDOG
Posted: 2007/8/12 15:07  Updated: 2007/8/12 15:07
 Re: whats this?
i just got dad to bronze a pipe into the tank of my sedan for a return, good old handy dad
ANGE
Posted: 2007/8/12 21:37  Updated: 2007/8/12 21:37
 Re: whats this?
i had a radiator place add a return line into my tank. also put in a 5/16 pickup as the old 1/4 would have been a little restrictive.
wasnt that expensive from memory
using the 1/4 pickup to fill a surge tank and then running bigger lines from that is a way around modding the tank if you must.
hotrocket
Posted: 2008/11/30 0:41  Updated: 2008/11/30 0:41
 Re: whats this?
ange any chance in seeing a pic in what your talking about............pictures tell a thousand words
Posted: 2008/11/30 2:35  Updated: 2008/11/30 2:35
 Re: whats this?
lol all my old photos are coming out...
