Main : Misc need help asap
[<   Previous  2459  2460  2461  2462  2463  2464  2465  Next   >]
need help asap
need help asapPopular
SubmitterfrankthedolphintrainerMore Photos from frankthedolphintrainer   Last Update2007/8/29 7:45    Tell a friendTell a friend
Hits2071  Comments3    0.00 (0 votes)0.00 (0 votes)
got the new malpassi rising rate reg for the carby today but it came with no instructions where do the lines go
im pretty sure 1 is the inlet from the tank number 3 is the outlet to the carb but what is 2 and 4. usually they only have 3 ports, the 3rd being the vacuum from the turbo to up the fuel under boost.
Booster
Posted: 2007/8/30 4:08  Updated: 2007/8/30 4:08
 Re: need help asap
on my malpassi on my carb turbo car it only has 3 pipes..
One on the top -to plenum to get vac/boost signal
Second on the side in the inlet from the pump which is T'd off to the carb
Thrid is the the return to the tank which is the bottom one.
so on yours i'd do
1-from pump
2-return to tank
3-outlet to carb
4-to plenum
Posted: 2007/8/29 7:46  Updated: 2007/8/29 7:46
 Re: need help asap
it seems to me that number 2 is the return and 4 must be the vacuum does this sound correct
BUNDY351
Posted: 2007/8/29 8:01  Updated: 2007/8/29 8:01
 Re: need help asap
might have to pull it apart to see how/where fuel flows through it
1200rallycar
Posted: 2007/8/29 8:05  Updated: 2007/8/29 8:05
 Re: need help asap
that is correct
