Main : Misc l20b wagon
[<   Previous  2418  2419  2420  2421  2422  2423  2424  Next   >]
l20b wagon
l20b wagonPopular
Submitterwagon1200More Photos from wagon1200   Last Update2007/9/12 12:13    Tell a friendTell a friend
Hits3795  Comments15    0.00 (0 votes)0.00 (0 votes)
It's in and running
TUF-110
Posted: 2007/9/12 22:47  Updated: 2007/9/12 22:47
 Re: l20b wagon
OMFG WAGON+L-SERIES= HOLY #### THATS AWESOME! well done mate looks the goods ice clean conversion
spenc
Posted: 2007/9/12 12:49  Updated: 2007/9/12 12:49
 Re: l20b wagon
hey looks nice wat mounts did ya use to get that to fit in and did ya have to cut any holes in the fire wall lol wats it go like commpred to the a12 lol cheers spence
WhiteSedan
Posted: 2007/9/12 13:10  Updated: 2007/9/12 13:10
 Re: l20b wagon
Another one is running!! Those airfilters are a nice fit, I was going to get the larger ones but was scared how close they would end up to the strut tower, misses it by a mile though, nice to see someone using those SU's.
Love your coil lead too.
wagon1200
Posted: 2007/9/12 13:19  Updated: 2007/9/12 13:19
 Re: l20b wagon
nah no holes cut, just panel beat the lower corners of the front of the tunnel with a hammer, as the L series is wider, and modify the engine mounts and make a crossmember, then only bit of cutting was 1/2 the gearstick hole but I welded that back in the other side.
it goes really well. :)
PIGDOG
Posted: 2007/9/12 13:22  Updated: 2007/9/12 13:22
 Re: l20b wagon
got any pics of the mounts and stuff, interesting to see how other people do it
sean i was running those SUs, twin 40s are so much better though
wagon1200
Posted: 2007/9/12 13:32  Updated: 2007/9/12 13:32
 Re: l20b wagon
yeah the mounts are and interesting mix of somebody elses work and then I modified 200b engine mounts to get the engine lower and further back so I had room up front and did not have to cut the radiator support.
I used a hyundai Lantra radiator and thermo and a craig davis one on the front in the original hole.
I'lll get some picks later.
spenc
Posted: 2007/9/12 13:38  Updated: 2007/9/12 13:38
 Re: l20b wagon
wot mounts did ya use iv got 2 l20bs and a hole 200b lol so hopefully i can use the 200b mounts lol wat kind of box and diff ya running
wagon1200
Posted: 2007/9/12 13:43  Updated: 2007/9/12 13:43
 Re: l20b wagon
the 1200 crossmember had the mounts trimmed to an angle simular to that of a 200b, then I cut the 200b mounts in 1/2 to finish the job and locate the motor lower and improve the mounting angles.
PIGDOG
Posted: 2007/9/12 13:57  Updated: 2007/9/12 13:57
 Re: l20b wagon
what have you done in regards to the sump?
wagon1200
Posted: 2007/9/12 13:58  Updated: 2007/9/12 13:58
 Re: l20b wagon
it's a bluebird l20b so the sump was perfect
WhiteSedan
Posted: 2007/9/12 14:02  Updated: 2007/9/12 14:02
 Re: l20b wagon
Which side is your alternator on? I guess still the pass side? I've left the alt on that side to simplify things, also gets too close to the battery tray.
Pigdog, those are my old su's, thats what I meant to say.
Interesting you got it to fit without modifying sump, not even beating it a bit? Do the bluey sumps have a bulge to the drivers side? I used a stanza sump on both engines.
wagon1200
Posted: 2007/9/12 14:04  Updated: 2007/9/12 14:04
 Re: l20b wagon
alternator is on the drivers side I used a universal hose, I was thinking about connecting the aircon again, or some other pump...
yeah now you mention it I did reshape it a little just so it would clear the crossmember, maybe 1/2cm with a hammer...
PIGDOG
Posted: 2007/9/12 14:14  Updated: 2007/9/12 14:14
 Re: l20b wagon
need to see this in person to compare engine fitment, my alternator no longer fitted on the drivers side as it was sitting so low, and had to modify the whole back of the sump bulge to clear the crossmember and also re construct the back to clear the drag link
wagon1200
Posted: 2007/9/12 14:18  Updated: 2007/9/12 14:18
 Re: l20b wagon
Yeah when ever we all meet up again your welcome to crawl all over it, it was in many pieces when the drag day happend so I could not make it. or if you are in the nth of Melbourne pop in and have a look.
cheers
PIGDOG
Posted: 2007/9/12 14:21  Updated: 2007/9/12 14:21
 Re: l20b wagon
yeah i didnt have the funds to get to the drag day anyway, surely there will be a cruise sometime in the nearish future
hopefully shortly after i have built a healthy L series
