Main : Members : evilsim hydraulic clutch - master cylinder w/ clutch plate
[<   Previous  8  9  10  11  12  13  14  Next   >]
hydraulic clutch - master cylinder w/ clutch platePopular
SubmitterevilsimMore Photos from evilsim   Last Update2007/10/31 12:32    Tell a friendTell a friend
Hits2351  Comments0    0.00 (0 votes)0.00 (0 votes)
at long long last this is in the car!!! i used a 180B master cylinder and a datrats firewall plate. the plate needed to be modified, the original hole was not used, a new one was drilled out(for the clutch master). the shaft of the master cylinder matches up perfectly with the clutch pedal. ill just use a nut/bolt from the cylinder's shaft into the clutch pedal arm (inside the car). thanks to joe, my cousins hubby for his work! maybee a weekend or two she'll be on the road!
