Main : Mechanical : Suspension B122 Front Suspension
[<   Previous  341  342  343  344  345  346  347  Next   >]
B122 Front SuspensionPopular
SubmitterddgonzalMore Photos from ddgonzal   Last Update2007/11/17 3:53    Tell a friendTell a friend
Hits5189  Comments7    0.00 (0 votes)0.00 (0 votes)
1985
iDatto
Posted: 2009/5/14 12:56  Updated: 2009/5/14 12:56
 Re: B122 Front Suspension
so if you have an a12 with the higher mounts so an a15 wont fit
i can just change the crossmemeber over and itll be sweet?
Posted: 2009/5/15 3:49  Updated: 2009/5/15 3:49
A12 and A15 use the same mounts if they are the same year.
But 1970-1973 engines use different mounts from 1974-up engines. Yes, you can change swap the crossmembers to suit:
* pre-1974 engine: Use 1970-1973 1200 crossmember
* 1974-up engine: Use 1974-up 1200 crossmember
Crossmember Tech wiki
kululadotgroen
Posted: 2007/11/17 16:43  Updated: 2007/11/17 16:43
It's almost like the ring change thread... How can it be quicker to fetch and drag a set of cutting torch and bottles than to get the spanner that fits, and save a part
Posted: 2007/11/17 19:32  Updated: 2007/11/17 19:32
I understand the sentiment. On the other hand, having been in the wrecking business -- where we dismantle hundreds of parts per day -- saving a few minutes each time using the cutting torch adds up to a big advantage at the end of the day...
Then you put the rest of the 1200 in the crusher!
oan878
Posted: 2007/11/17 6:29  Updated: 2007/11/17 6:29
is that stearing arm been cut with an oxy?
Posted: 2007/11/17 6:51  Updated: 2007/11/17 6:51
Looks like it. It is the fastest way of detaching this kind of part (cutting torch).
