Main : Misc 2006 UTE motor out 3
[<   Previous  2119  2120  2121  2122  2123  2124  2125  Next   >]
2006 UTE motor out 3Popular
SubmitterVelocitiMore Photos from Velociti   Last Update2007/11/24 4:23    Tell a friendTell a friend
Hits1642  Comments5    0.00 (0 votes)0.00 (0 votes)
All thisjust to replace the crank seal.
Velociti
Posted: 2007/11/25 8:38  Updated: 2007/11/25 8:38
 Re: 2006 UTE motor out 3
You are correct Dodgeman. It took us 30 to take to motor out. The seal went in easy but, the motor only went back in the next day as a result of a bottle of brandy and some cleaning up of the engine, engine bay and gearbox.
Dodgeman
Posted: 2007/11/25 14:29  Updated: 2007/11/25 14:29
Strictly speaking, if you clean the engine bay before you start, & you get a reasonably early start in the morning, then you can do the whole job & be driving it again by lunchtime if there are no other complications & you have the right parts ready to go.
Datsun, the right car for today's home mechanic.
Velociti
Posted: 2007/11/24 4:25  Updated: 2007/11/24 4:25
Note the TNT Branch.
Ill take a better pic after cleaning up the motor a bit.
Dodgeman
Posted: 2007/11/24 9:37  Updated: 2007/11/24 9:37
Be thankfull it's a Datsun. The engine comes out with minimal effort & the seal is easily removed & replaced as it is a one piece design fitted directly into a recess in the back of the engine. You got it easy.
In some other cars you would need to remove the oil pan, the rear main bearing cap & drop the crankshaft a little to gain access to the upper half of the seal.
Once again, Datsun saves.
