Main : Mechanical : Suspension My new Coupe struts!!
[<   Previous  112  113  114  115  116  117  118  Next   >]
My new Coupe struts!!Popular
SubmitterLOWTECHMore Photos from LOWTECH   Last Update2007/12/13 3:50    Tell a friendTell a friend
Hits2064  Comments18    0.00 (0 votes)0.00 (0 votes)
These are my custom front struts. They are 1200 spindles, welded to a 510 tube with a Koni race insert and Eibach 250 lb. spring. I used a Wilwood Dynapro single caliper which has the same piston size and mounting lugs as the original but is stiffer and weighs less than a pound!Hawk autocross pads and a Wilwood 10.25" two-piece disc,  capped with Datsport's camber plates.
levey
Posted: 2010/3/16 11:29  Updated: 2010/3/16 11:29
 Re: My new Coupe struts!!
Sweet setup!
nzdatman
Posted: 2010/3/17 6:31  Updated: 2010/3/17 6:31
sexy struts. very nice setup. are the discs solid or vented?
funny how aussies seem to call 4 pot calipers 4 spots? do you guys call a four cylinder engine a four spot too?
Posted: 2010/3/17 15:59  Updated: 2010/3/17 15:59
Online!
In america we call them four-piston
DatsAndy
Posted: 2010/3/16 10:10  Updated: 2010/3/16 10:10
It's so easy for us as humans to jump to the negative's especially when it comes to other peoples projects. Nice struts mate keep up the good work.
cheater_5
Posted: 2007/12/13 4:02  Updated: 2007/12/13 4:02
wow, love the cheese grater disks. Dont expect pads to last forever haha.
Very sexy setup you have there. Are 510 strut 50mm or 45mm internal dia?
Looks like ground control coilover sleeve aswell?
Let us know how the spring rate is like in the 12.
frankthedolphintrainer
Posted: 2007/12/13 12:01  Updated: 2007/12/13 12:01
wow, thats insane you better watch out not to roll your car...frontways like a sumersault . you must have deep pockets
im surprised that you stuck with the same stud pattern, why?
LOWTECH
Posted: 2008/7/18 7:40  Updated: 2008/7/18 7:40
Building it as a vintage road race car. That's why I couldn't use a 4 pot caliper. (These are only $90 bucks apiece though!) I'm using American racing Libra wheels, 13x7's.
steveo
Posted: 2008/7/18 7:45  Updated: 2008/7/18 7:45
wow!!!! that a nice bit of hardware! have you ot these in the car and tested them yet? how well do the pull you up?
LOWTECH
Posted: 2008/7/18 7:50  Updated: 2008/7/18 7:50
Haven't tried em yet! Rob Walker, who has one of the fastest road race 1200's around, told me that the stock 1200 calipers with good pads stops his race car easily. These as stiffer, with a much bigger diameter disc for better lever action so they should work great without adding any unsprung weight! We'll see though when I get that car on the track!
LOWTECH
Posted: 2008/11/4 4:36  Updated: 2008/11/4 4:36
UPDATE! I finally got these struts on the car! Wow is all I can say! The pedal is rock hard and the car stops ridiculously fast! I haven't done any measured stops yet but the feel is outstanding. Plus the huge holes in the disc make this great electric motor hum while hard braking! The 250 LB. springs were way too stiff for street, maybe alright for the track. I dropped down to 175 for now which is working great!
Rallytwit
Posted: 2008/11/4 4:44  Updated: 2008/11/4 4:44
mmmm yeah 250lb springs would knock your molers out after about 6 miles on the 405. Rob Walker would know 1200's for sure since he's been racing the them for about 35 years. I guess I never quite got the right pads in the stock calipers as they always seemed a tad weak.
Tom.
possum1200
Posted: 2008/11/4 7:51  Updated: 2008/11/4 7:51
to my surprise and what will surprise many others is that willwood calipers are not expensive for what they are
ZigZag
Posted: 2008/11/4 7:57  Updated: 2008/11/4 7:57
man these look sweet as.... ive got Baz from datsport.com making me up some custom R31 struts and disks for my 1200... they should do a good job of stopping
LOWTECH
Posted: 2008/11/4 7:59  Updated: 2008/11/4 7:59
YEP! Only $90. American for the Dynapro single each!
2QK4U
Posted: 2010/3/15 4:24  Updated: 2010/3/15 4:49
Are four spot calipers availabe too suit the caliper mounting and that disc? Can you give us part numbers? Just finished my coilovers and need a solution for brakes. I'd like too try a setup like yours but run 4 spots if possible. Also want to stay under 13" wheels.
1200rallycar
Posted: 2010/3/16 6:58  Updated: 2010/3/16 6:58
looks sexy but i have to wonder what the area of the pad is compared to the area of those big holes. when the hole is at the centre of the pad you would be reducing the contact area by 50% it appears???
LOWTECH
They're 47mm inside, 50mm outside. It pretty much slip fit over the 1200 tube. Haven't run it yet so I can't comment on the spring rate...
