Main : Mechanical : Fuel Injection EFI Manifold for Twin cam conversion
[<   Previous  153  154  155  156  157  158  159  Next   >]
EFI Manifold for Twin cam conversionPopular
SubmittersikyneMore Photos from sikyne   Last Update2008/1/8 0:48    Tell a friendTell a friend
Hits3586  Comments16    0.00 (0 votes)0.00 (0 votes)
A little more progress.
Cameron_Datto
Posted: 2008/1/9 8:19  Updated: 2008/1/9 8:19
 Re: EFI Manifold for Twin cam conversion
Looks very HORNY !
sikyne
Posted: 2008/1/8 1:18  Updated: 2008/1/8 1:18
This is the secondary set of injectors, the primary will be on the bends on the runners.
The secondary set should pull more heat from the intake charge, helping to prevent detonation.
pager
Posted: 2008/1/8 2:20  Updated: 2008/1/8 2:20
I would go as far to say this is the hottest A series out there. Top effort
dattodude
Posted: 2008/1/8 3:15  Updated: 2008/1/8 3:15
Yes this 'hand beaten' result is better than sex.
It is ART too.
b110coupe
Posted: 2008/1/8 4:05  Updated: 2008/1/8 4:05
Quite a regular
its looking awesome Simon. so the plenum is all welded up i take it? Nice!
frankthedolphintrainer
Posted: 2008/1/8 10:16  Updated: 2008/1/8 10:16
those runners seem so long how long are they?
sikyne
Posted: 2008/1/8 10:25  Updated: 2008/1/8 10:25
Thanks all, the runners are 18" long(455mm).
The two halves are not welded together yet. There is another photo ive posted showing inside the plenum, maybe someone can add it to this thread as i dont know how.
kululadotgroen
Posted: 2008/1/8 20:13  Updated: 2008/1/8 20:13
A series? How so, is it an A series block with some other 16V head on it?
EDIT: Sorry, went and read some more of his posts, A series block with some Kawa head on it...
sikyne
Posted: 2008/1/8 20:30  Updated: 2008/1/8 20:30
Thats it, A14 with cbr 1100 motorbike head.
For forced induction we have to multiply engine capacity by 1.7 to work out what class we will be in.
EG 1.4lts x1.7 =2.38lst
With this engine i have the option of destroking an A12 crank to get me in the under 2lts class..
kululadotgroen
Posted: 2008/1/8 20:38  Updated: 2008/1/8 20:38
Ok then Honda head...:i-) I hope that you make the power your aiming for, that it wouldn't have been better to just have taken an A12 and turbo that.
I like that you are trying to do something totally different though.
sikyne
Posted: 2008/1/8 20:45  Updated: 2008/1/8 20:45
It was posible to use the A12 but the A14/A15 block allows the use of a longer conrod for a better rod/stroke ratio.
I just hope the block stays together.
B210sleeper
Posted: 2008/1/9 3:10  Updated: 2008/1/9 3:10
that's niiice!
is the head used a secret?
Can you build me a nice intake for a turbo conversion? maybe a exhaust too!
LAGWAGON
Posted: 2008/1/9 3:47  Updated: 2008/1/9 3:47
looking good mate, this is definately the most highly developed and custom a series i have ever heard of. keep up the good work, leave the roughness for my stuff...
D
Posted: 2008/1/9 4:01  Updated: 2008/1/9 4:01
From: under the Firmament LOL no twiglight effect BS
Make sure you consider the e15 rods which are beef, 40mm journals and 140.645mm long
sikyne
Posted: 2008/1/9 9:27  Updated: 2008/1/9 9:27
Thanks D, could be an option for an A12 crank.
Once the timing chain sprockets come back i`ll make the timing case, it will have a manual chain tensioner adjustment through the side.
Most of my spare time goes into this project so making manifolds for others is probably out at this time, sorry B210sleeper.
