Main : Mechanical : Body and Interiors progress today
[<   Previous  3707  3708  3709  3710  3711  3712  3713  Next   >]
progress today
progress todayPopular
SubmitterfrankthedolphintrainerMore Photos from frankthedolphintrainer   Last Update2008/1/20 9:39    Tell a friendTell a friend
Hits2680  Comments16    0.00 (0 votes)0.00 (0 votes)
im trying to decide where to put the intercooler and its orientation, the choices are
1- to have it where it is  - problem is its low and may get damaged by stones ect ect. but looks the best
2- to have it where it is but flipped upside down so the pipes are on the top - problem is i have to cut alot more it fits the shape of the gap better.
3- cut away more of the panel and move it up higher - problem the bumper will be covering half the cooler preventing airflow which then kinda defeats the purpose of a cooler
well throw me your opinion
cheater_5
Posted: 2008/1/20 19:10  Updated: 2008/1/20 19:10
 Re: progress today
im going to have to agree and say that putting it right out front for everyone to see is just plaib ugly and show off. Put it infront of the radiator and shroud everything else off so the air flow will have to go through it. If you put it out front with no shroud like it is then the air isnt going to go through it so much anyway, just follow the path of least resistance and go around. And its more vulnerable to being destroyed.
Its a no brainer.
datsun_lover
Posted: 2008/1/31 17:51  Updated: 2008/1/31 17:51
Quite a regular
 Re: progress today
i installed my intercooler behind. in between the grill and the radiator. . there a gap between this two. just cut what you need it will fit nicely.
Laney
Posted: 2008/1/31 22:43  Updated: 2008/1/31 22:43
 Re: progress today
i like it where it is it looks wicked. . .
i like this one its diffrent but i like he should move the number plate though lol
Posted: 2008/2/1 4:33  Updated: 2008/2/1 4:33
 Re: progress today
yeah that licence plate would be blocking almost all the airflow
sunny
Posted: 2008/1/20 12:26  Updated: 2008/1/20 12:26
 Re: progress today
Why not get a cheap valance ( import panel )
and cut the piece directly above the cooler away (were the stainless trim goes) that way you can raise it , a couple of half bumpers and a double custom grille.
Trix
Posted: 2008/1/20 10:37  Updated: 2008/1/20 10:37
 Re: progress today
For looks I will go with the outside!!! If you have bad roads like we have I will rather mount it behind the grille to protect it!
Either way I am sure it will look great.
sssute
Posted: 2008/1/20 10:45  Updated: 2008/1/20 10:45
 Re: progress today
Behind the grill, it only takes a stone to hole the cooler, then your engine could injest the ally cooler bits as well as any dust, dirt or water.
Why risk destroying your engine.
campo
Posted: 2008/1/20 10:48  Updated: 2008/1/20 10:48
 Re: progress today
sssute makes a good point. but it still looks wicked there.. is that one of those ebay radiators. how well did it fit? does it sit high. did you have to cut anything to make it sit right?
Posted: 2008/1/20 11:24  Updated: 2008/1/20 11:24
 Re: progress today
yeah its a ebay jobby its the one out of my white ute theres a few more pics of it in my photos, surprising the bonnet still clears it. i did think about puting it behind the grill but after doing this on the other ute i feel that it blocks the radiator way too much and it limits the airflow not to mention the radient heat from the rad is very high causing the cooler to become heated itself. so in short its definetly going to go down where it is its just how low is the question, but thanks for all the comments as they are valued answers
dattodude
Posted: 2008/1/20 11:47  Updated: 2008/1/20 11:47
 Re: progress today
if you put it down that low, it will just be an interheater. Where does the air on the other side go??
I agree with the others. I put mine behind the grille, because I don't get on very well with police officers.
Posted: 2008/1/20 11:56  Updated: 2008/1/20 11:56
 Re: progress today
the panel behind it is slightly sloped rearwards (about 75degrees) and has approx 2inchs gap between the cooler and the panel.
as for cops the ville severly lacks them
ANGE
Posted: 2008/1/20 10:47  Updated: 2008/1/20 10:47
 Re: progress today
id rather have no intercooler than have one there, or visible anywhere on the front.
but if it has to be intercooled. hide it behind the grille.
kegs
Posted: 2008/1/20 10:15  Updated: 2008/1/20 10:15
 Re: progress today
i have the same sized intercooler put it behind your grille looks ####house on a datsun that low.
campo
Posted: 2008/1/20 10:20  Updated: 2008/1/20 10:20
 Re: progress today
i like it where it is. kinda makes it obvious. i like it
LittleFireyOne
Posted: 2008/1/20 10:29  Updated: 2008/1/20 10:29
 Re: progress today
That's where I was thinking of putting an oil cooler once, but it would need a couple of layers of strong mesh if it was going there.
