Main : Mechanical : Drive Train Custom prop shaft and fuel transfer pipe
[<   Previous  591  592  593  594  595  596  597  Next   >]
Custom prop shaft and fuel transfer pipePopular
SubmitterBUNDY351More Photos from BUNDY351   Last Update2008/1/28 3:02    Tell a friendTell a friend
Hits2426  Comments9    0.00 (0 votes)0.00 (0 votes)
Heres a pic of my custom propshaft (so hopefull no more embarrising start line breakages).  In the back ground is the stainless fuel transfer pipe to connect my origional fuel fill point to the new skyline fuel tank
dongdong0507
Posted: 2008/1/28 11:50  Updated: 2008/1/28 11:50
 Re: Custom prop shaft and fuel transfer pipe
I thought there would be power loss in coupling there due to the angle... as my friend customize the control arm to adjust it to the right angle in his B310...
or u would drag until it is parallel?
PIGDOG
Posted: 2008/1/29 5:22  Updated: 2008/1/29 5:22
think the pinion is supposed to be parrallel with the gearbox output shaft, as the tailshaft angle will change depending on the ride height
dont think you would notice any power loss due to the slight angle in the unis......unless your cars really underpowered
BUNDY351
Posted: 2008/1/30 11:22  Updated: 2008/1/30 11:22
LIKE MINE .
My pinion angle and gearbox output shaft are pretty dam close to parallel so I am happy.
dongdong0507
Posted: 2008/1/28 7:41  Updated: 2008/1/28 7:41
the drive shaft's and final gear's angle is not parallel?
kululadotgroen
Posted: 2008/1/28 9:28  Updated: 2008/1/28 9:28
It will be when he puts some decent torque trough it...
BUNDY351
Posted: 2008/1/28 11:12  Updated: 2008/1/28 11:12
OK, Yes it is the diff and fuel tank from an R31 skyline but a sedan not a wagon but I am sure there is no difference in the 2.
Yes you could relocate the fuel filler but it was just ALLOT easier to run a short pipe from the origional fill point.
As for the angle of the diff/propshaft, they dont have to be parallel but you also dont want any HUGE angles. Just have a think of some of the 4WD's out there with massive lift kits in em and imagine what angles the propshafts are in them, some run double carden shafts to reduce the angle but its still pretty harsh.
hotrocket
Posted: 2008/1/28 4:55  Updated: 2008/1/28 4:55
Question....looking at the fuel filler pipe, i wounder if you can relocate the filler pipe to the back of the 1/4,.....
prob no room to do so
hotrocket
Posted: 2008/1/28 4:19  Updated: 2008/1/28 4:19
hey champ is that a skyline r31 diff,...and the skyline fuel tank is it from a wagon!!!
rod.
