Main : Misc a Dip into the right side of 14 seconds
[<   Previous  1857  1858  1859  1860  1861  1862  1863  Next   >]
a Dip into the right side of 14 secondsPopular
SubmitterkululadotgroenMore Photos from kululadotgroen   Last Update2008/2/2 11:20    Tell a friendTell a friend
Hits2669  Comments12    0.00 (0 votes)0.00 (0 votes)
...as is shown in the picture of the results, I made it into the 13's...
kululadotgroen
Posted: 2008/2/26 7:05  Updated: 2008/2/26 7:05
 Re: a Dip into the right side of 14 seconds
I was wondering where this damn thing went, but I found it. Actually my wife found it looking for something else...
Tyrie
Posted: 2008/2/26 7:14  Updated: 2008/2/26 7:14
wow 177kw is awesome, what boost is that at?
Mine just made 146kw on 12psi, and ran a 13.2@171km/h.
You really need a locker and better tyres!
kululadotgroen
Posted: 2008/2/26 8:01  Updated: 2008/2/26 8:01
Thanks for the kudos, that was at 0.8bar. I always thought bar = psi/10, but a quick Google and one converter later it seems that it's 11.6psi... I suspect that my turbo is slightly larger than yours, and may flow a lot more at the same boost setting, from there the difference.
Here's the site which gives the spec for my turbo, Master Power, and a pic of it, mine is the 810001 in the in the middle...
1200GXman
Posted: 2008/2/26 9:42  Updated: 2008/2/26 9:42
If I compare this conversion with the CA18DET that you guys do, I would gladly take this conversion. Reasons:
1. About the same power as the CA18DET conversion.
2. Less weight than the CA18DET conversion.
3. No tunnel mods needed.
4. Still lots of engine bay space to work.
5. Easier to get registered because it's 1600cc.
One bad thing is however that with the CA18DET it is still Nissan/Datsun related. This conversion will unfortunately make it a Datsun/Toyota hybrid.
Tyrie
Posted: 2008/2/26 9:58  Updated: 2008/2/26 9:58
yeah its possible, but my high-flowed T3 is not a small turbo for a 1.6L. I would put the difference down to my old motor, its done a lot of km's.
kululadotgroen
Posted: 2008/2/14 7:58  Updated: 2008/2/14 7:58
Official site for the club that hosts these street racing events... WPMC Street Racing
And the results as posted on their site, you might notice that I was the sole Datsun entrant on the day, only a Nissan Sentra came close to being a Datsun... Results(pdf)
ANGE
Posted: 2008/2/14 8:09  Updated: 2008/2/14 8:09
what mph did you run on the 13.7 pass?
is that 165kw at the wheels?
with bigger/stickier rubber you should see
12's with ease.
i ran 13.9@99mph with only 114rwkw.
congratulations by the way.
kululadotgroen
Posted: 2008/2/14 12:26  Updated: 2008/2/14 12:26
They weren't taking speed on the day, or rather their measuring equipment only takes time and not speed. They have recently bought the timing equipment from another raceway that closed, so they'll have speed measurments soon.
Yes, at the wheels. But who knows really, these dyno machines rarely if ever measure the same between different ones, but I can say that my car does feel much stronger than before the engine was reconditioned. Boost comes in much earlier, and throttle response is also much quicker. O, and since I moved from Pretoria to Cape Town, I also lost about 1800m in altitude, which would probably also help the figure go up a bit.
I've decided not to go racing again before I made up some tram rods, added some stickier rubber, got some decent boost pipes and rebuilt the zorst with mandrel bends. I'll see what it does then. And I need to get the reaction times down... a lot....
That is pretty swift, considering you're not using any boost.. I did a 14.1@167km/h(+/-105mph?) before we moved down here.
Thanks for that.
kululadotgroen
Posted: 2008/2/2 12:09  Updated: 2008/2/2 12:09
Yep that's me 4th on the list, and proud of it. Made a 13.75, still running the 185x60x13 tires. Took a few tries though, and finally figured out that these damn Nangkang tires must be made of some weird compound, and that they needed some good warming up. We also let lots of air out, and finally settled on 0.8bar of pressure, where I got the best traction. With traction I mean that I wasn't still burning the tires in 3rd as well... If I could just get my reaction times down, but lights were a bit funny, very quick from white to green... The run was against a Toyota Corolla, running a SR20DET(go figure)... He was running 102.6 racing juice, and the turbo didn't look to standard, his best time for the night was 14.1...
And if anyone noticed, I updated my signature, pay particular note to the 165kw/260nm, up from the old 145kw/217nm...
O, and here is a vid of the skid I did when running against that Corolla... smoke'em...
lowendtheory
Posted: 2008/2/2 12:50  Updated: 2008/2/2 12:50
that's awesome! congratulations, the datto sounds mean in your burnout
A14force
Posted: 2008/2/2 21:07  Updated: 2008/2/2 21:07
I also found that my car ran quicker the harder I smoked my nankang too.
