Main : Misc 13b 2dr Blue Drag 1c
[<   Previous  6918  6919  6920  6921  6922  6923  6924  Next   >]
13b 2dr Blue Drag 1cPopular
SubmittermatbighatMore Photos from matbighat   Last Update2003/6/5 1:59    Tell a friendTell a friend
Hits5387  Comments6    0.00 (0 votes)0.00 (0 votes)
Now, now ... Moroso even makes a race pan for this motor to fit a 1200.
D
Posted: 2003/6/5 11:04  Updated: 2003/6/5 11:04
From: under the Firmament LOL no twiglight effect BS
 Re: 13b 2dr Blue Drag 1c
COuld you please please get pics from the mounts?? Ive got the 51mm ida carb, 13b pp, s4 turbo box etc but would like to see how the mounts go on the 1200 so I could adapt something to the 1000. Most mounts Ive seen are solid mounts which are ####e for durability for any engine.
MadTimo
Posted: 2003/6/5 11:12  Updated: 2003/6/5 11:12
D, I just used RX7 mounts bolted to the chassis rails in my 1600 and then cut and welded the front engine cross-member. Couldn't be easier, and I can't imagine it being much different in a 1200 or 1000
D
Posted: 2003/6/5 11:24  Updated: 2003/6/5 11:24
What you do with the sump did you have any clearance probs. Where is this morosso sump for rotary converted 1200 I want one.
Posted: 2003/6/5 18:45  Updated: 2003/6/5 18:45
MadTimo
Posted: 2003/6/6 3:20  Updated: 2003/6/6 3:20
Forgot about the sump. Yes, there was clearance problems, my sump was custom made to fit
Team_Dat
Posted: 2004/3/16 4:54  Updated: 2004/3/16 4:54
What is involved in fitting a 13B into a Datsun does the engine need to be set back or forward?
i know that you need new mount for engine g/box and a different diff, but what else?
