Main : Members : L18_B110 current pic of L18_B110's 1200
[<   Previous  14  15  16  17  18  19  20  Next   >]
current pic of L18_B110's 1200Popular
SubmitterL18_B110More Photos from L18_B110   Last Update2008/4/18 23:33    Tell a friendTell a friend
Hits3877  Comments16    0.00 (0 votes)0.00 (0 votes)
most obvious change is the new spoiler, which still needs some re-working to match up to the flares before painting. A new intercooler will fill the gap in the front, which will leave the radiator more open to airflow.
oda70
Posted: 2014/4/13 0:51  Updated: 2014/4/13 0:51
 Re: current pic of L18_B110's 1200
Miss this beast
ANGE
Posted: 2014/4/13 12:09  Updated: 2014/4/13 12:09
where is it now days? Ive always liked this coupe
L18_B110
Posted: 2014/4/15 4:48  Updated: 2014/4/15 4:48
jeffroj over in WA bought it. I'd assume he still has it but haven't kept in touch...
greendog
Posted: 2008/4/23 14:47  Updated: 2008/4/23 14:47
mr plough! thats massive are gunna shorten it a bit?
L18_B110
Posted: 2008/4/24 1:22  Updated: 2008/4/24 1:22
I was actually thinking about making up an undertray and splitter closer to the ground...
L18_B110
Posted: 2008/4/18 23:51  Updated: 2008/4/18 23:51
the spoiler and new intercooler location should go a long way towards sorting a slight overheating problem I had last November at QR. The current intercooler covers pretty much the whole radiator, and the end tanks are in front of the rad core blocking airflow.
The spoiler will prevent alot of air from going under the front of the car, so there'll be a low pressure area under the engine bay now for all the hot air to flow out under the car. the spoiler should also help a little on high speed corners.
the air filter will also be relocated to recieve a better supply of ambient air instead of being partially behind the radiator.
The overheating issue is also the reason I've gone back to the bonnet with the scoop. a bit more cool air forced in over the turbo's side can't really hurt.
the front is also 15mm lower to get the rollcentre down a little. some pics from the Australian Hillclimb Championship last year show some problems characteristic of having the front roll centre too high.
I've also got new front and rear swaybars for it, but I'm a little concerned about the size of the rear bar - its a bit big. Might have to get a custom one bent up, or maybe balance it out with higher rate front springs.
wolki101
Posted: 2008/4/19 6:58  Updated: 2008/4/19 6:58
looks nice and tough. rear swaybar? does it have an independant rear end?
L18_B110
Posted: 2008/4/19 8:55  Updated: 2008/4/19 8:55
no mate. it's still live axle and leaf springs. it's common to fit swaybars to live axles too.
bert
Posted: 2008/4/19 11:36  Updated: 2008/4/19 11:36
Been busy Harry! Good to see,you don't have a mould of the bonnet scoop do you?I don't have a 4b to take one off and don't fancy buying a new one unless i really have too.
Whens the test day?Interested to know your thoughts afterwards
Cheers
L18_B110
Posted: 2008/4/19 23:52  Updated: 2008/4/19 23:52
still lots to do yet - and waiting on the intercooler to arrive... hoping to give it a shakedown towards the end of next month at QR.
I don't have a mould of the scoop mate.
converted
Posted: 2008/4/20 5:20  Updated: 2008/4/20 5:20
she's morphing
Burke_a_lot
Posted: 2008/4/20 5:30  Updated: 2008/4/20 5:30
looks sweet! good work! keep it up!
datto1000wagon
Posted: 2008/6/11 3:20  Updated: 2008/6/11 3:20
bert i think the scoop is off a nissan patrol or similar 4wd like a pajero?
L18_B110
Posted: 2008/6/11 3:49  Updated: 2008/6/11 3:49
yep, its Patrol. apparently they're pretty cheap from Nissan.
bert
Posted: 2008/6/11 8:08  Updated: 2008/6/11 8:08
Yes i know what it is guys,but thanks anyway.Seeing as how i'm such a tight arse i knocked one up out of foam the other day(Signwriters usually have foam lying around)and pulled a mould out.It's nothing fancy just functional,so after i clean it (the mould)up a bit i'll make one up and shove it thru the glass bonnet from the inside and goo it in
D
Posted: 2008/6/23 11:52  Updated: 2008/6/23 11:52
From: under the Firmament LOL no twiglight effect BS
I like the spoiler attached to the bumper bolts really good lines with retro touches.
