Main : Members : PIGDOG 2L L18 in and running
[<   Previous  51  52  53  54  55  56  57  Next   >]
2L L18 in and runningPopular
SubmitterPIGDOGMore Photos from PIGDOG   Last Update2008/5/1 10:20    Tell a friendTell a friend
Hits4754  Comments33    0.00 (0 votes)0.00 (0 votes)
been driving it 3 days now and its pretty fun....especially when the cam kicks in
crzy_1200_ute
Posted: 2008/10/14 8:30  Updated: 2008/10/14 8:30
 Re: 2L L18 in and running
i say the black can spray paint LOL
simmos_datto
Posted: 2008/5/3 10:30  Updated: 2008/5/3 10:30
does that say datsun 1200 in the top?!? if so thats very cool!
baldy
Posted: 2008/5/2 11:48  Updated: 2008/5/2 11:48
Looking good mate, coming along well for all the hard work you have put into it .Your getting a bit of some satisfaction now what radiator are you running in it.It fits a glove.
LittleFireyOne
Posted: 2008/5/2 22:49  Updated: 2008/5/2 22:49
Where's the Fanta injection?....
Burke_a_lot
Posted: 2008/5/1 10:35  Updated: 2008/5/1 10:35
that mad!
revhead001
Posted: 2008/5/1 10:47  Updated: 2008/5/1 10:47
What sort of wotk has the donk had done to it?
WhiteSedan
Posted: 2008/5/1 10:50  Updated: 2008/5/1 10:50
You'd have to of been smiling all week long
Nice.
TUF-110
Posted: 2008/5/1 11:30  Updated: 2008/5/1 11:30
Nice to see your "Factory' rocker cover there sir
Ronald
Posted: 2008/5/1 12:01  Updated: 2008/5/1 12:01
and those, ahemm, "stock" carbies.
nah looking nice mate
scotty01
Posted: 2008/5/1 11:35  Updated: 2008/5/1 11:35
what's up with that rocker cover? 1200?? L18's didnt come out in any 1200s did they? custom job im assuming.
PIGDOG
Posted: 2008/5/1 11:56  Updated: 2008/5/1 11:56
whats this, you've never heard of an L12 before???
its the rare one that came in my car just to confuse people
specs
Datsun stroker 1998cc L18, w block 86mm SR pistons. L20b nitrided crank, stanza rods with 9mm rod bolts. ARP head studs, Modified oil pick-up and high volume oil and water pump. Ported heads, 280zx valves, 44 inlet 36 exhaust, 74 cam. 45mm webbers, 36mm chokes on datrally manifold series2 bluebird re-graphed dizzy and coil rebuilt 90amp alternator and starter. Lightened flywheel, 6cly.exedy rally spec pressure plate solid centre ceramic 4 puck clutch. Pacemaker extractors engine fully balanced including clutch.
so whitesedan. did i win?
WhiteSedan
Posted: 2008/5/1 12:02  Updated: 2008/5/1 12:02
You won bud!
Hows the gearbox holding up?
PIGDOG
Posted: 2008/5/1 12:14  Updated: 2008/5/1 12:14
theres a prize for whoever can point out the most non stock parts in this pic
WhiteSedan
Posted: 2008/5/1 12:17  Updated: 2008/5/1 12:17
Wiper motor?
PIGDOG
Posted: 2008/5/1 12:19  Updated: 2008/5/1 12:19
non stock
cant play the game in reverse
ANGE
Posted: 2008/5/1 12:22  Updated: 2008/5/1 12:22
ahhh finally!
any figures? estimates?
whats the prize were playing for?
oil breather non stock
WhiteSedan
aftermarket black primer?
PIGDOG
Posted: 2008/5/1 12:26  Updated: 2008/5/1 12:26
estimate of power was 100rwhp in 40 degree weather on a tuning dyno....about as rough as it gets
stock parts that i can see in the engine bay would be the little electrical doover on the drivers side strut tower and.....the body
ANGE
Posted: 2008/5/1 12:29  Updated: 2008/5/1 12:29
steering box
PIGDOG
Posted: 2008/5/1 12:31  Updated: 2008/5/1 12:31
yay 2 whole stocks things
WhiteSedan
Posted: 2008/5/1 12:34  Updated: 2008/5/1 12:34
Stock wiper motor wiring?
PIGDOG
Posted: 2008/5/1 12:35  Updated: 2008/5/1 12:35
yeah just noticed that
L18_B110
Posted: 2008/5/2 0:58  Updated: 2008/5/2 0:58
good to see! I really have a soft spot for L powered 1200's. hopefuly my 120Y will have an L20 sitting in its engine bay in a few weeks time.
it's strange combo of crank/rods/pistons. L16 rods are very short compared to L20B rods, but it should be very torquey! and that cam should really have lots of grunt from 2000rpm onwards. If you have to wait for it to 'come-on', the cam timing's probably a bit retarded.
PIGDOG
Posted: 2008/5/2 1:14  Updated: 2008/5/2 1:14
yeah i was thinking about the we they have stroked it...i was thinking it would have made more sence to use L18 rods as L16 are longer...so with longer rods and longer stroke the piston would be well and truely out of the L18 block(as i dont think the pin height would change enough to compensate)
but thats the way it is and it seems to work so i'll only start complaining if something breaks and isnt what its meant to be
cam doesnt come on till 3500rpm and ive been told to only rev it to 6500
would be good if the cam came on a bit earlier as then it would make up for the crappy gearing
B120dat
Posted: 2008/5/2 8:39  Updated: 2008/5/2 8:39
Hey Pigdog well done mate!!.... looks really good and bet it sounds good. Hows it handle??
I think you should move the coil, cause if you get blow back or back fire or something could put some fuel on the coil. doubt it would happen but
Dodgeman
Posted: 2008/10/14 3:05  Updated: 2008/10/14 3:05
Poster: PIGDOG Date: 2008/5/1 22:14:17
You are going to need to clearly define 'stock' as it applies in this instance.
You might say, ... if it doesn't have a Datsun 1200 part number, then it's not stock & the whole engine, radiator & other stuff is then non stock.
Alternately, you might say that if it doesn't have a Datsun/Nissan part number of any kind, then it's not stock & that changes everything.
So what are the rules here?
Oh yeah, will anyone actually want the prize? [whatever it might be]
ROConnor
Posted: 2008/10/14 7:45  Updated: 2008/10/14 7:45
Im gona say the Rocker cover!!! because as far as I'm aware there was neve a 1200cc L'series
soooooo.... WHAT DO I GETT??
Anonymous
i love taht rocker cover, glad you finished it finally. Ohh and the "boof" bar too
Anonymous
Posted: 2008/5/1 12:21  Updated: 2008/5/1 12:21
love th spring holding the dip stick in too, very original
D
Posted: 2008/5/2 10:23  Updated: 2008/5/2 10:23
From: under the Firmament LOL no twiglight effect BS
when are doing the KA24e 12V head conversion?
HYP014
Posted: 2008/5/3 12:12  Updated: 2008/5/3 12:12
Quite a regular
May i sugest from experiance, please move your coil away from the air filter! Why u ask, good old webbers splash fuel in to air filter socks, and if u get a stray spark out of the coil lead BANG! Those filters are like jiffy fire lighters, not good. i lost a 180B this way.
As for the rest i like it lots!
About the comment D made has any one done the KA24 head conversion yet? If not I know who has done the 16 valve head on a 2400 stroker. yes it can be done.ask if u want to know more.
Quinn
Posted: 2008/10/13 20:11  Updated: 2008/10/13 20:11
hell yea i want to know more! Probably best to start a new thread so as to not crash this one... cant wait for more info!
