Main : Misc A15 motor is in
[<   Previous  1511  1512  1513  1514  1515  1516  1517  Next   >]
A15 motor is in
A15 motor is inPopular
SubmitternismoMore Photos from nismo   Last Update2008/5/2 10:53    Tell a friendTell a friend
Hits3907  Comments7    0.00 (0 votes)0.00 (0 votes)
Hi everyone, well I just finished putting in a worked A15 motor into my green 120y coupe.
I pulled out my worked A12, as I have had this A15 siiting in my shed for a while now, and like most of us, wanted more power.
tom210
Posted: 2008/5/3 9:39  Updated: 2008/5/3 9:39
 Re: A15 motor is in
sick
nismo
Posted: 2008/5/3 10:13  Updated: 2008/5/3 10:13
 Re: A15 motor is in
Thanks guys, I took it around the block last night for a run, and everything is working fine.
I also bought an Exedy heavy duty clutch for it aswell and put it on, just to be sure.
(Don't want any slipping)
I can't wait to get it run in, so I can try it out a bit.
So if you see a green 120y coupe taking it steady you now know why.
It should be a blast to drive especially with the overdrive 5-speed attached to it.
Keep the comments rolling,
Cheers.
revhead001
Posted: 2008/5/3 10:27  Updated: 2008/5/3 10:27
 Re: A15 motor is in
It is a very 'giggety' clean little 'giggety' jigger that's for damn sure... 'gooooo'
What is that green? Is it the origional green? If so what is it called. 2 of my vans are that colout but the colour id is missing.
nismo
Posted: 2008/5/3 10:47  Updated: 2008/5/3 10:47
 Re: A15 motor is in
Hi revhead, yes it is the original colour, and
it's a 1974 120y coupe.
I think the colour is called olive yellow, but I will check the under bonnet paint code number and let you know.
I have only seen one or two 120y's in this colour and they were both wagon's.
Cheers.
lukeADE
Posted: 2008/5/3 15:07  Updated: 2008/5/3 15:07
 Re: A15 motor is in
I think the colour could be huon green... my family had a coupe that colour back in the 80s
Good job on the A15... looks great!
Burke_a_lot
Posted: 2008/5/3 3:27  Updated: 2008/5/3 3:27
 Re: A15 motor is in
nice job!
