Main : Misc gt30 mounted
[<   Previous  1502  1503  1504  1505  1506  1507  1508  Next   >]
gt30 mounted
gt30 mountedPopular
SubmittershaunMore Photos from shaun   Last Update2008/5/5 8:12    Tell a friendTell a friend
Hits2329  Comments12    0.00 (0 votes)0.00 (0 votes)
dodgy phone pic ill get some more when it comes home
shaun
Posted: 2008/5/5 10:30  Updated: 2008/5/5 10:30
 Re: gt30 mounted
was stoked when i seen it finally mounted
Laney
Posted: 2008/5/5 12:00  Updated: 2008/5/5 12:00
 Re: gt30 mounted
what the hell are the specs on this thing it looks massive lol
Lachie
Posted: 2008/5/5 12:45  Updated: 2008/5/5 12:45
 Re: gt30 mounted
Look super tough mounted high What power are you hoping to get?
dattodude
Posted: 2008/5/5 21:17  Updated: 2008/5/5 21:17
 Re: gt30 mounted
That does look awesome, but it looks like you'll have no boost until 6000rpm. Who recommended the turbo?
I'm trying not to be negative, because it does look awesome.
tappet
Posted: 2008/5/5 23:36  Updated: 2008/5/5 23:36
 Re: gt30 mounted
its a gt3076r with antisurge compressor housing, rated at 310-525 hp..
great choice of turbo..
will be an absolute animal at top end
you sohuld see 18-20psi at around 4700 rpm on a stocker ca
gt3076r specs
rupertscoupe
Posted: 2008/5/6 0:27  Updated: 2008/5/6 0:27
 Re: gt30 mounted
good lord i thought my turbo was large...this thing will make serious power, it this ute a daily driver?
can't wait to see the dyno figures on this..
i love people who are not scared of a little lag...my turbo doesn't get full boost till about 4200 rpm but i only have it bolted to a stocker atm..can't wait till the cams and head work are done. what stage is your motor at?
campo
Posted: 2008/5/6 0:56  Updated: 2008/5/6 0:56
 Re: gt30 mounted
what manifold are you running? custom or one of them off the shelf jobs?
shaun
Posted: 2008/5/6 7:57  Updated: 2008/5/6 7:57
 Re: gt30 mounted
manifold is custom
turbo is a gt30
the guy i got it off said he got them built(2 of them)
its rated at 525hp .63 rear so it should be good for full boost about 4g im hoping, thats why i got a 3800 stally
not too sure on power but im hoping for 200rwkw@15psi before i rebuild the motor
hopefully
tappet
Posted: 2008/5/6 8:13  Updated: 2008/5/6 8:13
 Re: gt30 mounted
shaun
read my above post if u want the specs..
i didn't know it was an auto
depending on the diff gears
with a 3800 stall with a bit of brake u should be able to spool 15psi easily by 4000... .
shaun
Posted: 2008/5/7 8:51  Updated: 2008/5/7 8:51
 Re: gt30 mounted
yep thats the plan mate
rupertscoupe
Posted: 2008/5/7 9:22  Updated: 2008/5/7 9:22
 Re: gt30 mounted
200rwkw or 275odd rwhp with 15 psi will be a feat and a half, but if everything is efficient it is possible. i got 230 rwhp or 170 rwkw at 12psi out of my t04e/t3 hybrid before the big end bearings went bye byes....old ####e motors are not the go.... keep us posted
