Main : Mechanical : Wheels  PCD Conversion
[<   Previous  118  119  120  121  122  123  124  Next   >]
 PCD Conversion
PCD ConversionPopular
Submitter3RotorMore Photos from 3Rotor   Last Update2008/5/9 20:31    Tell a friendTell a friend
Hits2080  Comments1    0.00 (0 votes)0.00 (0 votes)
The wheel's flange makes it easy, I do not have to worry about the nut's that will hold the converter plate and disk together,  they slot in perfectly with the Wheel. The rim has an 35mm Offset, which is a bit too much, so the 12mm spacing fixes that problem perfectly as well...
