Main : Misc A14
[<   Previous  1448  1449  1450  1451  1452  1453  1454  Next   >]
A14
A14Popular
SubmitterretrorallyMore Photos from retrorally   Last Update2008/5/22 12:12    Tell a friendTell a friend
Hits2600  Comments16    0.00 (0 votes)0.00 (0 votes)
Inside
kululadotgroen
Posted: 2008/5/23 23:01  Updated: 2008/5/23 23:01
 Re: A14
My dad used to stand and with a pencil grinder grind the inside of his Ford kent engines to a shine. This was also done to the conrods to an extent, and the crankshaft webs. They said that it would drain the oil back faster, and create smoother surfaces that would move through the suspended oil cloud faster(crankscrapers would probably have worked better...). They did manage to rev those engines to 10000 rpm during some of the races, so there must have been some truth to it...
Painting the inside would give the same effect, and I have even heard of blocks being chromed on the inside...
EDIT: Disclaimer, the crankshafts and conrods were replaced with steel items from Datsun origin of some sort. Cast iron would never go to those rpms. I also remember that they used to leave more space between the piston tops and head, because the rods would literally stretch allowing the pistons to hit the head. At first they couldn't figure out why it would only "knock" above 8000...
retrorally
Posted: 2008/5/24 0:28  Updated: 2008/5/24 0:28
 Re: A14
Like I said;
Its not really necessary, maybe we do it to look good in photos on the internet and get people to make comments.......
Its worked so far!
A14force
Posted: 2008/5/24 2:56  Updated: 2008/5/24 2:56
 Re: A14
WOW,
The comments here have covered nearly every aspect of blocks. It's just for faster oil retrun to the sump.
Seasoned blocks (used) have been through so many thermal cycles (warmed up, and cooled down) that all the internal stresses (from the casting process have been relieved. (Race blocks have this done after being cast, by being heated up to within a koowee of melting. And being held there for a time, then allowed to cool slowly.)
As opposed to seasoning outdoors. Where (In times of old) motors would be left out in the open (In detroit) after they were cast. in the cold winter. We now now that prolonged exposure to cold tempratures, (Or shorter exposue to really cold tempratures) realigns the molecules in metals. From Austinite, to Martinsite. (or vise versa, I can't rememeber which way it goes) This process is know as crygenic anealing. They stopped doing it donkeys years ago in detroit. It makes the metal hard wearing, but without the embrittlement of heat anealing.
I dont know about pissing on a block though.
A14force
Posted: 2008/5/23 9:31  Updated: 2008/5/23 9:31
 Re: A14
What kind of paint did you use inside the block?
kululadotgroen
Posted: 2008/5/23 9:56  Updated: 2008/5/23 9:56
 Re: A14
As A14force said...
retrorally
Posted: 2008/5/23 10:28  Updated: 2008/5/23 10:28
 Re: A14
Its just a Dulux primer sealer.
1200GXman
Posted: 2008/5/23 12:18  Updated: 2008/5/23 12:18
 Re: A14
Why did you paint it on the inside?
I was always under the impretion that a engine must never be painted on the inside where it can flake of and mix with fluids.
retrorally
Posted: 2008/5/23 12:54  Updated: 2008/5/23 12:54
 Re: A14
We have always painted our blocks. Some people do it because it might allow the oil to drain back quicker (similar to polishing) . The main reason we do it is to seal the block, in case any of the loose casting decides to let go. Its not really necessary, maybe we do it to look good in photos on the internet and get people to make comments.......
Mitch_photog
Posted: 2008/5/23 12:56  Updated: 2008/5/23 12:56
 Re: A14
I was under the impression that if could be painted with a specific paint and this would improve water flow, cooling characteristics and also prevent corrosion and alike, however the paint is a specific type. As 1200GXman said I would be worried of it flaking off and blocking water flow, especially in tight areas like the radiator. I think that I have even read of an occurance of this happening and causing huge problems...
1200GXman
Posted: 2008/5/23 13:32  Updated: 2008/5/23 13:32
 Re: A14
I don't think it will happen with a "seasoned" block. I did some research about "seasoned" vs "new" engines to use for performance upgrading.
Apparently the definition of a "seasoned" block or engine is that it is a used engine that have twisted and heated up and cooled down many times to finally find a point where it will stop.These engines are preferred by performance engine builders as they apparently are better to use than building up a fresh out of the box engine.
As far as i know all A series engines have been used previously so I doubt it will have casting still coming off.
Nothing that a proper cleaning of the inside before assembly should'nt cure.
Just my opinion as I am still not comfortable with painting the inside of a engine.
beattie
Posted: 2008/5/23 13:54  Updated: 2008/5/23 13:54
 Re: A14
Yeh apparently BMW racing team in the DDC or whatever it is use a really old block(mileage) then stick it in a paddok and get the techs to piss on it I donno i heard it somewhere, i think my boss.
Cooling systems dont corrode if you use good coolant and look after it. Toyota genuine is one of the best ive found.
kegs
Posted: 2008/5/23 14:38  Updated: 2008/5/23 14:38
 Re: A14
beattie i dunno if that story is true but that idea is used to in a way treat cast iron as u cant heat treat cast iron you leave things like precision angle plates ( engineering/machining 90 machined and ground) you leave these out in the weather and rain then regrind em and the surface is tougher than normal cast iron.
datto1000wagon
Posted: 2008/5/23 14:47  Updated: 2008/5/23 14:47
 Re: A14
beattie i have heard that to but it was with some early mg engines that where left out in a paddick when they stopped producing during the world war they eventually remachined them to a useable state and they are tough as apparently
ang94541
Posted: 2008/5/23 16:37  Updated: 2008/5/23 16:37
 Re: A14
Glyptal paint
I think this stuff is normally used for electrical windings.
Also, I think if this paint flaked it would get in your oil not your water.
Mitch_photog
Posted: 2008/5/23 22:31  Updated: 2008/5/23 22:31
 Re: A14
haha, yeah, I didnt even think about 'what part' of the engine was painted... I just thought hmmm water goes around in there... lol, but its obvious that its oil in this case...
