Main : Misc Arias 4AG
[<   Previous  1406  1407  1408  1409  1410  1411  1412  Next   >]
Arias 4AG
Arias 4AGPopular
SubmitterDUMBOMore Photos from DUMBO   Last Update2008/5/31 3:38    Tell a friendTell a friend
Hits1643  Comments3    0.00 (0 votes)0.00 (0 votes)
Forged postons for 4AG/ZE from the states.  I plan to have them thermal coated before fitment
kululadotgroen
Posted: 2008/5/31 19:16  Updated: 2008/5/31 19:16
 Re: Arias 4AG
This should be lower compression than standard, but not as low as the 4AGZE pistons. Well atleast not as low as the first gen ones, the later ones had slightly higher compression, 8.9:1 as apposed to 8:1, and they may not have had the pocket in the middle. I haven't seen them yet, only the first lower CR ones. Standard 4AGE pistons have domes that protrude above the edge of the piston, into the combustion chamber in the head.
DUMBO
Posted: 2008/6/1 5:05  Updated: 2008/6/1 5:05
 Re: Arias 4AG
All that I have read on the net indicates you are correct. I have a non-oil squirter AE92 Bigport engine that these will be going into (not any time soon mind you). I am unsure if they would fit with the oil squirters that are fitted to the other blocks. From what i have seen these pistons have a machined cut-out on the bottom of the skirt for clearance. From what I have found I wont need the squirters in my application, and I will thermal coat them to prevent heat transfer to the piston in the first point and try and keep the heat in the combustion gass and hopefully help my spool rate for the turbo I am going to run. It's a case of "Suck it and see", If she turns into a lag monster and annoys the crap out of me, I'll down size the snail. I enjoyed your pics by the way!
