Main : Members : PIGDOG 200b/stanza coilovers
[<   Previous  46  47  48  49  50  51  52  Next   >]
200b/stanza coiloversPopular
SubmitterPIGDOGMore Photos from PIGDOG   Last Update2008/7/20 12:22    Tell a friendTell a friend
Hits2449  Comments4    0.00 (0 votes)0.00 (0 votes)
200b/stanza/240k strut shortened to suit st150 corrona struts (lots of available downwards travel)
alloy coilover sleeves and nuts with 200mm unknown rate spring
home made top hat(lathes are fun)
JIC camber tops
and then there is the r33 disc r32 caliper that takes up most of the pic
Dat50
Posted: 2008/7/21 4:11  Updated: 2008/7/21 4:11
Not too shy to talk
 Re: 200b/stanza coilovers
Looks like a good setup.
Would you actually be able to use all of that adjustment in height before the wheel/tyre hit the guard?
Any pics from the back of the disc?
PIGDOG
Posted: 2008/7/21 4:26  Updated: 2008/7/21 4:26
can use about 3/4 or the adjustment running 195 50 15s and R30 Ti rims before the spring hits the wheel, ride height depends on how longs the springs are....but at its lowest point the rim would almost be in the guard
i have also lathed the adjusting nuts down a bit and tapered the bottom one for that little bit extra clearance to the wheel
no pics of the coilovers from the back, but if you just want to see the caliper bracket have a look through my album
shouldnt be too hard to find a pic or 2, one of them has lots of other pics replied to it also
Dat50
Posted: 2008/7/21 5:31  Updated: 2008/7/21 5:31
Not too shy to talk
Cheers for that.
I was wondering about clearance to the spring perches and whether that would really limit the offset of the wheels you could utilise, especially seeing that adjustment can go down to be inline with the top of the disc
Does this mean the spring diameter is at about 62mm?
Good work
