Main : Mechanical : Body and Interiors Fron of coupe tacho
[<   Previous  4503  4504  4505  4506  4507  4508  4509  Next   >]
Fron of coupe tacho
Fron of coupe tachoPopular
SubmitterWattageMore Photos from Wattage   Last Update2003/6/26 4:06    Tell a friendTell a friend
Hits6313  Comments12    0.00 (0 votes)0.00 (0 votes)
Front view of tacho removed from 1200 coupe.
datski620
Posted: 2011/3/28 11:32  Updated: 2011/3/28 11:32
 Re: Fron of coupe tacho
the tach face is 98mm
UTE18L
Posted: 2004/3/14 8:56  Updated: 2004/3/14 8:56
One of these came with my ute when i bought it, i assume its from a coupe as well, how hard will it be to hook up to my dash.
My clock is already busted and i have one on my stereo so i plan on putting it there.
What will be required to hook it up??
2332owner
Posted: 2004/3/14 9:44  Updated: 2004/3/14 9:44
There's a discussion on here somewhere... may even be in the tech section... that includes a diagram simplifying the installation. With a CA18 though it would just be hooked up to the tach signal on the CPU. It bolts in place of the factory clock.
who_your_datty_1200
Posted: 2004/3/14 10:03  Updated: 2004/3/14 10:03
Hey if you need some help just let me know
2332owner
Posted: 2004/3/14 10:04  Updated: 2004/3/14 10:04
boofhead
Posted: 2007/7/7 13:18  Updated: 2007/7/7 13:18
quick question for some one who's played with the coupe dash and clock/tacho swaps .... do anyone know if its the same size as the clock in the centre console .. the one over the gear stick ?
like this one ----- V
PIGDOG
Posted: 2007/7/7 13:26  Updated: 2007/7/7 13:26
thinking of putting a tacho in there?
or does the clock not work
boofhead
Posted: 2007/7/7 13:32  Updated: 2007/7/7 13:32
dunno .... clock works but i'm going to have to relocate all the guages when the console goes in ... if i can fit a factory tacho into it then i will look into it and come up with somewhere else for the oil and water guages to go ....
phunkdoktaspok
Posted: 2007/7/7 14:54  Updated: 2007/7/7 14:54
It fits right into the console with the factory mounting holes. I had it like this in my old yellow sedan years ago.
Posted: 2007/7/7 22:38  Updated: 2007/7/7 22:38
Factory brochures show the Tacho sometimes in the dash, sometimes in the console. Ditto for the Clock.
For more details, and for wiring, see: wiki - Tachometer
lisasdecals
Posted: 2011/3/28 1:38  Updated: 2011/3/28 1:38
Does anyone have the measurements for the face of the tach?
Posted: 2011/3/31 7:18  Updated: 2011/3/31 7:23
is it exactly the same size as the speedometer?
