Main : Misc dat383
[<   Previous  1093  1094  1095  1096  1097  1098  1099  Next   >]
dat383
dat383Popular
Submitterdat383More Photos from dat383   Last Update2008/8/24 8:40    Tell a friendTell a friend
Hits1907  Comments7    0.00 (0 votes)0.00 (0 votes)
dat383
dat383
Posted: 2008/8/25 12:09  Updated: 2008/8/25 12:09
 Re: dat383
you have a good eye!
it is a gemini rack.it is about the narrowest front facing rack you can get,but the rack ends are too long and have to be cut down and re-threaded.the front radius rods need to be modified to clear and the struts swapped left to right so the original steering arms face forwards.
fabricate a suitable mount to hold the rack securely and turn down the input shaft of the rack to suit what ever uni setup and steering shaft you want to run.then you have to connect it to the factory steering column...
but thats another story altogether.
don't do it unless you must,its too bloody hard!
Quinn
Posted: 2008/8/25 18:18  Updated: 2008/8/25 18:18
 Re: dat383
Thanks a lot dat383! I only really want to run a rack and pinion setup for improved steering feel and better turn ratio, I know the standard 1200 setup is pretty good but if there is a easy(ish) option I'll do it. Is there any other setups people have used? I think a toyota starlet or AE86 rack would be pretty close...
dattosans
Posted: 2008/11/10 14:10  Updated: 2008/11/10 14:10
 Re: dat383
i already tested with the rolla ke70 rack on my b310 it fail it stuck at the starter hmmm what a frustrated..
Quinn
Posted: 2008/8/25 0:53  Updated: 2008/8/25 0:53
 Re: dat383
I would really love to know what steering rack you used as I want to get rid of the old steering box setup...
rupertscoupe
Posted: 2008/8/25 1:05  Updated: 2008/8/25 1:05
 Re: dat383
that makes two of us....this looks great...
wagon1200
Posted: 2008/8/25 1:23  Updated: 2008/8/25 1:23
 Re: dat383
it looks like a gemini unit to me...
