Main : Misc ford edis pulley
[<   Previous  1014  1015  1016  1017  1018  1019  1020  Next   >]
ford edis pulley
ford edis pulleyPopular
Submitterdatto1000wagonMore Photos from datto1000wagon   Last Update2008/9/21 6:14    Tell a friendTell a friend
Hits2114  Comments4    0.00 (0 votes)0.00 (0 votes)
started making a new pulley to mount the edis 36-1 tooth cog
Posted: 2009/3/15 20:52  Updated: 2009/3/15 20:52
 Re: ford edis pulley
Nice. Use with MegaSquirt or EDIS controller box.
Wiki articles:
MegaSquirt
EDIS
Look ma, no dizzy!
D
Posted: 2009/3/16 1:08  Updated: 2009/3/16 1:08
From: under the Firmament LOL no twiglight effect BS
You can also get the thin pressed steel ones from a late ford transit
crank which are easily spot or tack welded onto the original steel
pressed pulleys. It eliminates alot of extra work and overall weight.
But if you are making a new pulley from alloy this is great.
datto1000wagon
Posted: 2009/3/16 1:14  Updated: 2009/3/16 1:14
not alloy but mild steel and the original is cast iron so weld ing it is out of the question there is another pic of it a bit more completed
