Main : Misc KB10 Rear end
[<   Previous  975  976  977  978  979  980  981  Next   >]
KB10 Rear end
KB10 Rear endPopular
SubmitterbertMore Photos from bert   Last Update2008/9/30 5:59    Tell a friendTell a friend
Hits2326  Comments12    0.00 (0 votes)0.00 (0 votes)
Another as requested
frankthedolphintrainer
Posted: 2008/9/30 6:07  Updated: 2008/9/30 6:07
 Re: KB10 Rear end
whats the deal with the block and the hose?
Anonymous
Posted: 2008/9/30 6:09  Updated: 2008/9/30 6:09
 Re: KB10 Rear end
im pretty sure its his sway bar set up
L18_B110
Posted: 2008/9/30 6:10  Updated: 2008/9/30 6:10
 Re: KB10 Rear end
lol "hose"
its a swaybar
bert
Posted: 2008/9/30 6:12  Updated: 2008/9/30 6:12
 Re: KB10 Rear end
Lol
Daveman
Posted: 2008/9/30 6:24  Updated: 2008/9/30 6:24
 Re: KB10 Rear end
where is the front ends of the swaybar attached to?
steveo
Posted: 2008/9/30 6:32  Updated: 2008/9/30 6:32
 Re: KB10 Rear end
hose?! LMAO!!!!! that must be trick photoghraphy!
How thick is the sway bar?
bert
Posted: 2008/9/30 6:42  Updated: 2008/9/30 6:42
 Re: KB10 Rear end
There are 3 photos,with all the important bits in frame,and Steveo it's 10mm solid mount,about equivalent to 13mm if in rubber or the like
Posted: 2008/9/30 7:48  Updated: 2008/9/30 7:48
 Re: KB10 Rear end
lol it looks so smooth and thin, i didnt even think of it eing a sway bar.
bobthebuilder
Posted: 2008/9/30 10:15  Updated: 2008/9/30 10:15
 Re: KB10 Rear end
Hi Bert
What diameter is your front bar compared to the rear sway bar ?
Still gunna build one but have had a dose of procrastination.(starting to feel better now though).
Thanks for your help.
Cheers
Bob
bert
Posted: 2008/9/30 11:15  Updated: 2008/9/30 11:15
 Re: KB10 Rear end
G'day Bob,standard 1200 bar on the front of this one...17mm for memory and 10mm on the back,both solid mounted(no rubber or the like)just rose joints.
I'm sure someone will pick me up on the 1200 bar if i'm out a mm or 2,i think the 120Y and Sunny are 19mm...TOO MANY BLOODY CARS HERE and i'm getting too old to remember
Ianey
Posted: 2009/6/21 3:47  Updated: 2009/6/21 3:47
 Re: KB10 Rear end
G'day Bert.
How tightly is the swaybar clamped in those alloy blocks? Can it still swivel? Did you buy those blocks or make them yourself? What size rose joints are you using?
Cheers.
