Main : Misc Remote Brake reservior
[<   Previous  927  928  929  930  931  932  933  Next   >]
Remote Brake reserviorPopular
SubmittersikyneMore Photos from sikyne   Last Update2008/10/15 10:53    Tell a friendTell a friend
Hits1942  Comments10    0.00 (0 votes)0.00 (0 votes)
Had to mount these here, no room under the dash!
LittleFireyOne
Posted: 2008/10/15 11:01  Updated: 2008/10/15 11:01
 Re: Remote Brake reservior
Hey man, Racecars are Function over fashion. Coincedently that is what makes them look so good to me, mmmm racecars. Haven't much on the motor recently, how's that going?
sikyne
Posted: 2008/10/15 11:19  Updated: 2008/10/15 11:19
Very slow with engine.
Just received an email saying pistons are ready, rods should only be another week..
ROConnor
Posted: 2008/10/15 11:21  Updated: 2008/10/15 11:21
Hav you changed the shap off the peddles slightly? or is it just the angle? in unother pick they did look a little un'urgonomick. I prais the time effort and talent that has gon into this car!
sikyne
Posted: 2008/10/15 11:49  Updated: 2008/10/15 11:49
Hi Connor, I changed the profile on the pedals, well spotted.
WhiteSedan
Posted: 2008/10/15 11:51  Updated: 2008/10/15 11:51
Great looking pedal setup, I just bought a setup from US, can't wait to fit it all, what master cylinders are you using, and where did you get the reseviours?
Cheers
Sean
sikyne
Posted: 2008/10/15 12:05  Updated: 2008/10/15 12:05
Hi Sean,
The reserviors are from Bendigo specialist brake and clutch. and were only $18 each from memory. They are supplied with a mounting bolt (14mm) and i tapped this thread into the aluminium block you can see in the pic.
The master cyls are AP (short series) from competition friction, $220 each.
3/4" for the front and 13/16" for the rear. With a balance bar between.
WhiteSedan
Posted: 2008/10/15 12:39  Updated: 2008/10/15 12:39
Thanks for that mate,
I was going to use a 1" tandem until I could afford to make a pedal box some time in the future but decided to just buy one now and get it done.
I will look into finding some single m/cyls in 3/4 and 13/16, they need to have verticle mount with bolt spacing of 57mm or 2.25".
sikyne
Posted: 2008/10/15 22:25  Updated: 2008/10/15 22:25
Sean, you will probably have to go smaller master cyls than me.
To get precise you have to calculate things like pedal ratio, caliper piston area, pad area, rotor diam, front / rear weight of car and centre of gravity height of car.
Im guessing the biggest difference between your set up and mine would be pedal ratio, as mine is 8:1. You will find yours is closer to 3 to 5:1 meaning smaller master cylinders would be used.
I would suggest you try 5/8 on the front and 3/4 on the rear as a starting point.
This should get you well within balance bar tunability and without too much pedal effort.
If you can get them fairly cheap it wont hurt your pocket too much to make a change after testing if need be.
Simon
WhiteSedan
Posted: 2008/10/16 8:51  Updated: 2008/10/16 8:51
Thanks heaps simon, Im not sure on pedal ratio but have asked the company that makes the pedal box.
Have a look here
I have started a thread about m/cyls and have a pic of the pedal box i have ordered.
Sean
