Main : Misc my a12gx build up
[<   Previous  927  928  929  930  931  932  933  Next   >]
my a12gx build up
my a12gx build upPopular
SubmitterspencMore Photos from spenc   Last Update2008/10/16 10:04    Tell a friendTell a friend
Hits1311  Comments4    0.00 (0 votes)0.00 (0 votes)
my a12gx build up
spenc
Posted: 2008/10/16 10:19  Updated: 2008/10/16 10:19
 Re: my a12gx build up
l16 inlete valves
a14 exhaust valves
40 thou over pistons (74mm)
crow cams rs2000 double valve springs
ect
Dodgeman
Posted: 2008/10/16 10:35  Updated: 2008/10/16 10:35
I'm a little surprised that since you were buying new pistons, that you would go for such a small size.
The standard A12A used 75mm pistons for 1237cc but you would need the A12A rods as these are the right length but have the larger wrist pin hole that all standard pistons above 73mm used.
The A12A rods are available in the US but not here in Australia, so you should be able to source them without too much drama.
Go for the A14 pistons at 76mm & you have the standard A13 spec which yeilds 1270cc.
The A12A rods would also be needed to make it work but all of these pistons share the same deck height.
The 1200 & later A12 cylinder blocks should handle this bore size without difficulty & I ran my 1200 GX engine with 'first oversize' A14 pistons' [76.5mm] for years. [1287cc]
All of this is inside the 1300cc limit for race class purposes but reduces the disadvantage of those engines that are closer to 1300.
It also makes for a very peppy 1200 GX
spenc
Posted: 2008/10/16 11:47  Updated: 2008/10/16 11:47
standard a12 bore is 73mm
u can use a14 pistons but u need differnt rods as the pin bore diamiter is different i think uc mazda pistons 77mm are the ones to go for as there flat top but in the precision auto parts catoluge is seez that the a10 piston are the same bore size as a12 but there dome top
(edit) dident see the a afer a12
yes you are right a12a or a13 used the 75mm pistons
