Main : Misc Speedo cable
[<   Previous  863  864  865  866  867  868  869  Next   >]
Speedo cable
Speedo cablePopular
SubmitterVelocitiMore Photos from Velociti   Last Update2008/10/26 9:39    Tell a friendTell a friend
Hits2113  Comments10    0.00 (0 votes)0.00 (0 votes)
Why do these thing only last 60000km. This is now my second one from new.
dattodude
Posted: 2008/10/27 11:10  Updated: 2008/10/27 11:10
 Re: Speedo cable
I think you'll find this is caused by poor/dirty ground strap from the engine to the body inside the engine bay.
It only takes once, and the cable it screwed, as it melts the nice polyethylene coating on the inside.
See how the cable's protective plastic appear worn..I'd say it melted during starter crank. Then when the cable gets some speed up, the plastic grabs and the cable snaps.
Velociti
Posted: 2008/10/27 12:25  Updated: 2008/10/27 12:25
 Re: Speedo cable
This does sound like a possible reason for the breakage. 3 weeks back the starter was battling to turn, I thought it was the cold weather, but it did this all day, the next day the battery was poked aswell. It was a new battery so the battery cant be at fault. Ill have a look at the earth cables to see if they are loose.
This is the gearbox end.
kululadotgroen
Posted: 2008/10/27 9:40  Updated: 2008/10/27 9:40
 Re: Speedo cable
Strange... The cable in my car is the original one I bought it with, which no doubt must have seen a few 100 thousand K's of mileage. I was still pondering the speedo setup when I realised that when I remove the W58 gearbox's electronic speed sensor, the Datsun cable screwed straight in there, it's drive even looked exactly the same as the electronic one... Have hit 0km/h a few times since the car got going, and though it does jump around sometimes, it's never broken...
Dad had a Ford once which also ate speedo cables at an alarming rate, there were no sharp bends in the cable/s anywhere. He eventually fixed it by putting some graphite powder in the outer along with the cable. Graphite powder is an excellent "lubricant" in such applications, because it's very slippery(duh), and it doesn't attract dust, which is a sure killer...
I wonder if the speedo itself might not be slightly "tigter" than normal...
1200GXman
Posted: 2008/10/27 10:16  Updated: 2008/10/27 10:16
 Re: Speedo cable
Mine is also still running the same cable for the last 30 years.
Is this the end that goes into the gearbox or the end that goes into the speedo.
Velociti
Posted: 2008/10/27 5:14  Updated: 2008/10/27 5:14
 Re: Speedo cable
Like is said, this is now the second one to break and the UTE now only has 110000km on the clock. Ill have a check for any sharp bends in the cable, but I doubt it thought.
Dodgeman
Posted: 2008/10/26 18:11  Updated: 2008/10/26 18:11
 Re: Speedo cable
I have never broken one in over a million miles of motoring, so there must be something wrong with the way it's installed. If there is a bend, or kink in the cable run, or excessive strain at the fitting, then you have problems.
benddatsun
Posted: 2008/10/26 22:11  Updated: 2008/10/26 22:11
 Re: Speedo cable
dont wind the speedo up so far. LOL
Posted: 2008/10/27 1:51  Updated: 2008/10/27 1:51
 Re: Speedo cable
Same here, using 35 year old cable, no problems with any Datsun. That's with Japan-built cable. Maybe the new Dacia bakkie will have better quality...
steveo
Posted: 2008/10/27 2:17  Updated: 2008/10/27 2:17
 Re: Speedo cable
same here! thats never happened to me before. The only time i've heard it happening before was in a mates 200b, it got ripped out while paddock bashing through a paddock, got caught on wire and fence post and ripped it clean out.
