Main : Misc 120y sloted rotors
[<   Previous  779  780  781  782  783  784  785  Next   >]
120y sloted rotors
120y sloted rotorsPopular
SubmitterhotrocketMore Photos from hotrocket   Last Update2008/11/10 23:10    Tell a friendTell a friend
Hits2834  Comments10    0.00 (0 votes)0.00 (0 votes)
had the struts powdercoated the calipers chromed and polished,
plus the bolts zinc coated aswell to look finished
hotrocket
Posted: 2008/11/11 2:37  Updated: 2008/11/11 2:37
 Re: 120y cross drilled/sloted rotors
I also have the diff boys shorting my R31 at the moment, then it will be powdercoated aswell,
I think its a much better finish then paint it
steveo
Posted: 2008/11/11 2:40  Updated: 2008/11/11 2:40
BLING BLING!!!!
Very niiiice!
How much did they set you back?
hotrocket
Posted: 2008/11/11 2:46  Updated: 2008/11/11 2:46
yeah i was pretty lucky $140 set,
they were telling me that they nomally retail at $110 each.......so i was cheering
ANGE
Posted: 2008/11/11 5:52  Updated: 2008/11/11 5:52
no expense spared and no detail overlooked.
quality!
what brakes are you running on the r31 diff?
im just concerned that your rear brakes may be visually a lot larger than your fronts?
hotrocket
Posted: 2008/11/11 6:40  Updated: 2008/11/11 6:40
R31, well that something i never looked into,
Do you think there be a problem maybe in hard braking where the rear mite lockup!!!
im bit unsure what brakes to run at this time, this is the easy opion at the time as there bugga all change,
i have a sortment of front brakes out the back, R31, 200B, bluebird and Gazelle's,
been trying them and finding out that they change the offset quiet alot,
skyline's i find it puts the wheel outside the guard,
i also swaped the spring perches around with 1200 purch to be able to fit wider wheels,
i noties that the lower b/joint and control on the 1200 to the skyline are very different abit of stuffing around there!!
a bit of trial time at the moment,
not unless you guy's no something i don't
hotrocket
Posted: 2008/11/12 1:32  Updated: 2008/11/12 1:32
the rear rotors are 15mm bigger than the fronts,
PIGDOG
Posted: 2008/11/12 8:09  Updated: 2008/11/12 8:09
could go S13 brakes with drum hubs, that way your strut offset wont change
hotrocket
Posted: 2008/11/12 8:16  Updated: 2008/11/12 8:16
yeah out here in the west S13 dont come by very much if at all... lol
i no what your saying, do they bolt onto the 120Y stub?
maybe il look into it next time im in sydney
PIGDOG
Posted: 2008/11/12 8:45  Updated: 2008/11/12 8:45
need to make an adaptor bracket for them, but dont think its really hard to make
