[< Previous 711 712 713 714 715 716 717 Next >]
My 1200
aca18t 2008/11/21 11:10 Tell a friend
1963 3 0.00 (0 votes)
| refitted engine today started to fit some braid made radiator & intercooler brackets as well |
| Poster |
Thread |
| TUF-110 |
Posted: 2008/11/21 22:43 Updated: 2008/11/21 22:43 |
No life (a.k.a. DattoMaster)   Joined: 2007/5/23 From: Wagga Wagga, NSW Posts: 1250 |
 Re: My 1200 gday mate could you post up a pic of a side view of the bay so i can see the clearance between cam angle sensor and radiator/cooler
Cheers Jake
| Poster |
Thread |
| campo |
Posted: 2008/11/21 23:12 Updated: 2008/11/21 23:12 |
Home away from home   Joined: 2006/5/20 From: Rocky Queensland Posts: 425 |
 Re: My 1200 is that a custom radiator or an off the shelf job?
| Poster |
Thread |
| aca18t |
Posted: 2008/11/22 0:48 Updated: 2008/11/22 0:48 |
Just can't stay away   Joined: 2004/7/7 From: Ashmore Gold Coast QLD Posts: 129 |
 Re: My 1200 Campo it is a S13 race it is 3 core and almost 55mm thick should keep it cool for cruising when I want
Tuf110 the fans are Corolla air con fans they pull ####load of air are 60mm thick due to the curveature on the blades, there is 15mm clearance on the front of the crank sensor and water pump pulley
Nick.
