Main : Members : steveo what turbo A14 does to axels
1  2  3  4  5  6  7  Next   >]
what turbo A14 does to axelsPopular
SubmittersteveoMore Photos from steveo   Last Update2008/11/22 7:05    Tell a friendTell a friend
Hits4623  Comments14    0.00 (0 votes)0.00 (0 votes)
axel out of my H145
lethal_john
Posted: 2010/12/15 11:02  Updated: 2010/12/15 11:02
 Re: what turbo A14 does to axels
we've got a couple of midget quick changes lying around, last one i bout was 2200 with cone axles, gears about 80 dollars. if you guys want a price delivered let me know
casey
Posted: 2010/12/12 8:23  Updated: 2010/12/12 8:23
winters diffs are great you can also buy DMI ones that are the same just abit cheaper. we have 6 kicking around the race shop but they are all for sprintcars and have splined axles and are way to big hahaha. and always remember when you change the gearsets its upsidedown snowman otherwise you might take awhile to get up to speed hahaha
D
Posted: 2010/12/12 8:33  Updated: 2010/12/12 8:33
From: under the Firmament LOL no twiglight effect BS
casey shows us a pic of the DMI ones!
the splined axles are easily solved.
steveo
Posted: 2010/12/14 9:39  Updated: 2010/12/14 9:39
Wow i haven't thought about this in ages!!!
You may or may not know that i adapted a H165 under the thou, its about 60mm bigger overall than the standard diff all worked quite well...............
So far!!!
I would love a winters complete rear end that would be awesome! The funds is what's holding me back! a man can only dream!!!
casey
Posted: 2010/12/10 1:45  Updated: 2010/12/10 1:45
go a welded H190 it will last for years of abuse
wolki101
Posted: 2010/12/8 21:48  Updated: 2010/12/8 21:48
winters quick change diffs are the #OOPS#, stupid light, like less than 50kg or something, can handle about 550hp, order them to whatever width you want, can change the diff ratio in 2 minutes, you dont even have to jack the car off the ground and the whole things are shiny aluminum and anodised.
i think they're about 3500, im getting one for my ute and will be buying it in the next 3-4 months, i can let you know prices etc when i find them?
D
Posted: 2010/12/10 11:54  Updated: 2010/12/10 11:56
winters quick change diffs are the #OOPS#, stupid light, like less than 50kg or something, can handle about 550hp, order them to whatever width you want, can change the diff ratio in 2 minutes, you dont even have to jack the car off the ground and the whole things are shiny aluminum and anodised. i think they're about 3500, im getting one for my ute and will be buying it in the next 3-4 months, i can let you know prices etc when i find them?
They are the bomb, Im sure with the exchange rate prices will be good.
Definitely keep us posted if you get it as youll be the first and it
will beat all the other aftermarket stuff by a long shot.
They can weigh under 30kg (26kg) without brakes!!!
D
Posted: 2010/12/6 2:59  Updated: 2010/12/6 2:59
Sorry didnt get back on this thread to answer your qs steveo
The winters quickchange is a pricey bit of gear for hot rods
and speedway racing machines. Not affordable compared to a
stock h190 which you can then get an alloy carrier from
datsun 1500 utes and some early vanetter/e20/c20 vans.
DATO_FREAK
Posted: 2010/12/7 12:49  Updated: 2010/12/7 12:49
Quite a regular
Haha, you don't need a turbo A14 to do that.
An A15 with extractors and 32/36 webber does that quite easily too.
Welded diff survived through about 4 axles like that, a gearbox, 2 rear uni joints in the tail shaft, an alloy diff housing, crown and pinion and finally cracked the centre :)
Posted: 2008/11/23 13:56  Updated: 2008/11/23 13:56
Yikes. Are these H145 axles the same as fitted to H150?
reuby_tuesday
Posted: 2008/11/23 15:52  Updated: 2008/11/23 15:52
Nice effort.
The splines don appear to show much wear. Is this after much abuse?
SLAM1024
Posted: 2008/11/23 22:52  Updated: 2008/11/23 22:52
nice work buddy
D
Posted: 2008/11/23 23:12  Updated: 2008/11/23 23:12
Steveo make sure you find a suitable lightweight replacement for the rear as the r31 is quite heavy.
Looks like h190 with rare alloy cover is your only option with lsd but the final price might be worth considering a Winters quickchange.
steveo
Posted: 2008/11/24 1:36  Updated: 2008/11/24 1:36
This was broken after i wound up the boost to 18psi and took it for a run around the block didn't give it that much abuse but when it comes to boost they don't handle that much, I've broken 2 others before this one so something has to be done!
D- i read your other post and i'm interested to know what model of car the rare H190 LSD with alloy carrier and finned bits comes out of? whats a winters quickchange?
I'm looking at putting H190 out of a TRX bluebird, but to my knowledge they don't have a LSD option, or do they? if that falls through i'll probably settle on a H165 out of a bluebird.
How much is the Nismo LSD centre for H165? i've seen it in the random picture box.
