Main : Misc can anyone identify this engine?
[<   Previous  581  582  583  584  585  586  587  Next   >]
can anyone identify this engine?Popular
SubmitterDatsunSSSMore Photos from DatsunSSS   Last Update2008/12/16 21:56    Tell a friendTell a friend
Hits3443  Comments12    0.00 (0 votes)0.00 (0 votes)
it was in a US 510
kululadotgroen
Posted: 2008/12/17 12:32  Updated: 2008/12/17 12:32
 Re: can anyone identify this engine?
Lots of space left for a nice turbo, and none of the heat soak/transfer problems associated with the L-series... Out of interest has anyone done a turbo conversion on one of these?
buzbox510
Posted: 2008/12/17 22:01  Updated: 2008/12/17 22:01
is a zed engine but to use the same transmision as an l series you need to change bellhousing
as a z series engine lean to the right and an l series lean the opposite way to put one in a 1600 all you need to do is swap left to right mount to change the lean angle plus bell housing hope this helps
DatsunSSS
Posted: 2008/12/18 20:13  Updated: 2008/12/18 20:13
thanks buz
spenc
Posted: 2008/12/16 21:58  Updated: 2008/12/16 21:58
z24 0r 22 not a bad motor simalar bottem end as the l series
DatsunSSS
Posted: 2008/12/16 22:23  Updated: 2008/12/16 22:23
whats the best? the L or the napz?
spenc
Posted: 2008/12/16 22:33  Updated: 2008/12/16 22:33
the z22 or z24 was more of a workhorse then the l series u can use the crank out of the z and put it in your l series and make a 2.2 stroker or 2.4 stroker
bert
Posted: 2008/12/17 2:38  Updated: 2008/12/17 2:38
This old beast is found in the old Nissan Navara's
spenc
Posted: 2008/12/17 3:15  Updated: 2008/12/17 3:15
yep my dad has one
Posted: 2008/12/17 5:36  Updated: 2008/12/17 5:36
The Z engine is basically an L engine with a crossflow cylinder head. So you can use same transmissions, etc. But has more power. That's 2.2 liters instead of 1.6 liters...
DatsunSSS
Posted: 2008/12/17 7:17  Updated: 2008/12/17 7:17
thanks for all
dazza1200
Posted: 2008/12/17 11:11  Updated: 2008/12/17 11:11
was a z18 and z20 too
