Main : Misc my carbs
[<   Previous  568  569  570  571  572  573  574  Next   >]
my carbs
my carbsPopular
SubmitterspencMore Photos from spenc   Last Update2008/12/20 6:32    Tell a friendTell a friend
Hits3083  Comments17    4.50004.50 (2 votes)
twin 45s and i not sure wot the others are
DatsAndy
Posted: 2008/12/20 12:12  Updated: 2008/12/20 12:12
 Re: my carbs
How much for the twin 45's ?
spenc
Posted: 2008/12/20 12:17  Updated: 2008/12/20 12:17
 Re: my carbs
there for my race car sorry andy just bought them todayvery good condition no play in the throttles ect gasket kit throw ect jusy need a clean or a bath in the ultrasonic cleaner
DatsAndy
Posted: 2008/12/20 12:20  Updated: 2008/12/20 12:20
 Re: my carbs
Did ya clarify what the other carbs are and how much for each of them ?
spenc
Posted: 2008/12/20 12:24  Updated: 2008/12/20 12:24
 Re: my carbs
ones a 32/36 weber
and the others 34/34 or something
thay both need rebuilds and (may) be missing parts unsure
taking offers on them or swaps for other things of interest like
ram tubes
filter socks
linkages for weber manifold
benny
Posted: 2008/12/21 3:59  Updated: 2008/12/21 3:59
 Re: my carbs
34 ADM 1's were fitted as factory to the Ford Falcon 4.1L [I forget which year though].
alot of the jets from a 34 ADM 1 will interchange into a 32/36 DGV-5A /DGAV /DGEV carb.
mains, emulsion tubes and air correctors. as these parts share the same basic part numbers. weber jets typically have a basic part number followed by a ". " then the size .
e.g 32/36 DGV-5A primary main jet has a part number 73801.135
the jet size is 1.35mm
Did I mention I like weber's............... hmmm weber
cheers
benny
spenc
Posted: 2008/12/21 8:09  Updated: 2008/12/21 8:09
 Re: my carbs
k banny its mesures 34/34 but the number are 23 24 is stamped on the sides of the carb
spenc
Posted: 2008/12/21 8:11  Updated: 2008/12/21 8:11
 Re: my carbs
yey got my gx ywin weber maifold today and im just about to purchase another coupe for parts
benny
Posted: 2008/12/21 22:41  Updated: 2008/12/21 22:41
 Re: my carbs
at a guess those numbers refer to the choke sizes in the carb bores. 23 mm primary and 24mm secondary. the throttle plate would be 34mm.. it would make for excellent mixture [air] velocity on the 4.1L from low down to mid RPM's. Right in the zone for steet driving in a std car
Pendles
Posted: 2008/12/21 23:31  Updated: 2008/12/21 23:31
 Re: my carbs
I used a 34 ADM on a mild A15 for a few years, primary circuit was almost spot on, the secondary jets and tube had to be closed up a little from memory. Worked really well.
Pulled it of a XF Falcon ('87ish) from memory.
Posted: 2008/12/20 7:17  Updated: 2008/12/20 7:17
 Re: my carbs
They look like Weber DGV (32/36)
spenc
Posted: 2008/12/20 8:24  Updated: 2008/12/20 8:24
 Re: my carbs
i know 1s a 32 36 but one has 2 throats azact same size
ROConnor
Posted: 2008/12/20 8:27  Updated: 2008/12/20 8:27
 Re: my carbs
could be a 38/38 or 40/40 and I'm sure they came in other size's aswell
spenc
Posted: 2008/12/20 8:47  Updated: 2008/12/20 8:47
 Re: my carbs
ill measure them up on m nday and see
spenc
Posted: 2008/12/20 8:57  Updated: 2008/12/20 8:57
 Re: my carbs
okay found a ruler and measured them ones 32/36 and the other is 32/32 i didnt even knoe thay made that small any 1 want to buy em
benny
Posted: 2008/12/20 11:47  Updated: 2008/12/20 11:47
 Re: my carbs
they look like 34 adm's to me..... there code will be stamped on the fuel bowl or base plate
spenc
Posted: 2008/12/20 12:10  Updated: 2008/12/20 12:10
 Re: my carbs
yep your right benny cherrs are thay any good
