Main : Mechanical : Body and Interiors Steering Lock with keylock and ignition switch
[<   Previous  3336  3337  3338  3339  3340  3341  3342  Next   >]
Steering Lock with keylock and ignition switchPopular
SubmitterddgonzalMore Photos from ddgonzal   Last Update2009/2/22 8:12    Tell a friendTell a friend
Hits1655  Comments8    0.00 (0 votes)0.00 (0 votes)
Part Number: 48700-H5010, includes break-off bolts -- japan market B210
DatsAndy
Posted: 2008/12/26 9:46  Updated: 2008/12/26 9:46
 Re: Steering Lock with keylock and ignition switch
Tyrie to remove the existing bolts i did what pigdog did with the one i got off him. Just get a hacksaw blade and broke it in say half and sawed in to the heads till i could get a flat head screwdriver in enough to undo them bit fiddly but got it out neatly, No butchering
dattodude
Posted: 2008/12/26 10:18  Updated: 2008/12/26 10:18
hacksaw is old school way to do it.
Get a dremel (or china copy) and use the cutoff grinding disc until you get a screwdriver slot!
Posted: 2008/12/26 19:11  Updated: 2008/12/26 19:11
Yes, all those methods work.
The one that doesn't cost any money is just use a center punch. In a pinch, you could use a nail. Slowly tap the punch to turn the bolt anti-clockwise. Tap, tap, tap. Eventually they spin out. It takes a while, but I have removed many of them using this method.
kelmo
Posted: 2008/12/26 21:02  Updated: 2008/12/26 21:02
DD,
Did you just aquire that part?
Ran the # through Nissan and show NLA
Posted: 2008/12/26 23:08  Updated: 2008/12/26 23:08
It's a Nissan Japan catalog part. I'm sure the USA part number is different.
Tyrie
Posted: 2008/12/26 8:19  Updated: 2008/12/26 8:19
cool, I'd never seen the break-off bolts unbroken before. Is there a special way to remove them or just drill the head off them?
steveo
Posted: 2008/12/26 9:23  Updated: 2008/12/26 9:23
I recently bought a new key barrel in the ute and all i did was do them up tight until they literally broke off.
I also had to use a cente punch to get the old bolts out, Pain in the ASS!!!
