Main : Misc A12 OR A14
[<   Previous  500  501  502  503  504  505  506  Next   >]
A12 OR A14
A12 OR A14Popular
SubmitterBandit_bluesMore Photos from Bandit_blues   Last Update2009/1/6 12:23    Tell a friendTell a friend
Hits3008  Comments13    0.00 (0 votes)0.00 (0 votes)
Asblik
Posted: 2009/1/7 3:59  Updated: 2009/1/7 3:59
Not too shy to talk
 Re: A12 OR A14
If you can't see it on the engine number, then you can measure it. From the top of the timing chain cover to the top of the block. The A12 is appr 10mm and the A14 is appr 20mm
Posted: 2009/1/7 5:49  Updated: 2009/1/7 5:49
 Re: A12 OR A14
It's not A12A or A15, since those have two machined pads above the fuel pump.
So it must be either A12, A13 or A14.
Look here:
spenc
Posted: 2009/1/7 6:54  Updated: 2009/1/7 6:54
 Re: A12 OR A14
it looks more like a 120y a12to me
ajrdadsun
Posted: 2009/1/6 15:31  Updated: 2009/1/6 15:31
 Re: A12 OR A14
that is some what correct but that eng is a A12a
and is stamped on block as so.
datto1000wagon
Posted: 2009/1/6 19:55  Updated: 2009/1/6 19:55
 Re: A12 OR A14
id have to say a14 as it also has by the looks of it a smooth case gearbox which are of the 60series variety
DatsunSSS
Posted: 2009/1/6 20:06  Updated: 2009/1/6 20:06
 Re: A12 OR A14
cant you read the number in the block? lool
it is a a14 , the exaust manifold is like my a14.
about the ports, you can see the number inside the valve cover.
ajrdadsun
Posted: 2009/1/6 15:18  Updated: 2009/1/6 15:18
 Re: A12 OR A14
hi all, i may be wrong but don't the A12 and the A14 have the dizzy in differnt places.
but i may be wrong again but by the pic it
looks by the placement of the dizzy hole
this eng is a A14. just throwing that out there
Bandit_blues
Posted: 2009/1/6 15:22  Updated: 2009/1/6 15:22
 Re: A12 OR A14
The late A12 also have the dizzy in the same spot! Can we compare it by the exhaust?
Bandit_blues
Posted: 2009/1/6 12:24  Updated: 2009/1/6 12:24
 Re: A12 OR A14
Is there any way to know if is an A12 or A14 by this photos?
Another angle:
beattie
Posted: 2009/1/6 12:38  Updated: 2009/1/6 12:38
 Re: A12 OR A14
I would say A12 because it looks to have a round port manifold. On the NON manifold side it should stamped on the block up near the head what A series it is.
Bandit_blues
Posted: 2009/1/6 12:52  Updated: 2009/1/6 12:52
 Re: A12 OR A14
The guy that wants to sell me assure me that is an A14 with oval port head.
silvia-specr
Posted: 2009/1/7 7:32  Updated: 2009/1/7 7:32
 Re: A12 OR A14
I would say a14, has alot of mouting brackets for emissions,on the thermostat housing and valve cover.
