Main : Misc rekitting R31 rear calipers
[<   Previous  487  488  489  490  491  492  493  Next   >]
rekitting R31 rear calipersPopular
SubmitterhotrocketMore Photos from hotrocket   Last Update2009/1/10 0:45    Tell a friendTell a friend
Hits1968  Comments5    0.00 (0 votes)0.00 (0 votes)
fitted new rubber kit, plus adding chrome and zinc plating to the bling
hotrocket
Posted: 2009/1/10 0:54  Updated: 2009/1/10 0:54
 Re: rekitting R31 rear calipers
im having troubles in pushing the piston back,
ive smeared a little grease around the rubber and piston, plus im using the right tool for the job and still no go??.........
ive also noticed that there a slot on the front of the piston plus theres mark where sumone has tryed before....is it ment to be screwed in not pushed!!.......im trying to fit shoes
help on this guys
frankthedolphintrainer
Posted: 2009/1/10 1:35  Updated: 2009/1/10 1:35
im not 100% sure but dont brake pistons usually have the hollow part facing out
PIGDOG
Posted: 2009/1/10 1:57  Updated: 2009/1/10 1:57
nah thats the correct way the piston goes, and yes you need to screw the piston in. or the easier way is to take it all out and screw the handbrake doover into the piston first then just push it all in
they are an arse of a caliper
hotrocket
Posted: 2009/1/10 5:41  Updated: 2009/1/10 5:41
your tell me stuffing around with it for awhile there,.....
so i ask you guys if sumone would have none how its done..........and thanku Pigdog.
