Main : Members : Demojob Internal Clutch Master
[<   Previous  12  13  14  15  16  17  18  Next   >]
Internal Clutch MasterPopular
SubmitterDemojobMore Photos from Demojob   Last Update2003/7/22 12:30    Tell a friendTell a friend
Hits3292  Comments5    0.00 (0 votes)0.00 (0 votes)
This is out of an 80 model Nissan urvan (internal clutch master)  the filler tube for the resivour is actually on an angle as the master is mounted on an angle.
Posted: 2016/12/7 22:50  Updated: 2016/12/7 22:50
 Re: Internal Clutch Master
Demojob's explanation of this photo: hydraulic clutch to datsun 1200 conversion
This pic was taken above the steering wheel with the dash face removed
Demojob
Posted: 2003/7/22 12:31  Updated: 2003/7/22 12:31
A simlpe 90degree bracket is needed to be made up to mount this master
Cheers
Damo
GREAT FOR CLEARENCE IN ENGINE BAY
Wattage
Posted: 2003/7/30 4:49  Updated: 2003/7/30 4:49
So I gather by using the internal clutch master off the urvan, you would pretty much be able to match it up to any actuator for a hydraulic clutch correct?
I'm thinking about using one of these masters myself, as I like the idea of an uncluttered and neat engine bay.
Leigh
Demojob
Posted: 2003/7/30 9:04  Updated: 2003/7/30 9:04
true but the urvan is good as it's made to fit on an angle but if you wanted to get technical with brackets you could then put most clutch masters here.
Cheers
Damo
jack
Posted: 2003/8/27 14:42  Updated: 2003/8/27 14:42
i noticed that in my mum's brand spankers corolla it has a clutch master with no resourvoir. It has a hose going to the brake resourvoir.
I wonder if this is possible to rig up with some datsun parts (or a combination of new other parts, etc)??
PS - i still don't quite understand where we're looking in this pic.
