Main : Misc ebay goodies
[<   Previous  421  422  423  424  425  426  427  Next   >]
ebay goodies
ebay goodiesPopular
Submitterdatto1000wagonMore Photos from datto1000wagon   Last Update2009/1/24 13:06    Tell a friendTell a friend
Hits2306  Comments16    0.00 (0 votes)0.00 (0 votes)
gx carbs and gx headers pluss a sway bar for a 1k
datto1000wagon
Posted: 2009/1/24 23:17  Updated: 2009/1/24 23:17
 Re: ebay goodies
sway bar for the rear of a 1000 apparently and those carbs should find there wat onto an a10
clyons8
Posted: 2009/1/24 23:23  Updated: 2009/1/24 23:23
 Re: ebay goodies
I still don't see how a sway bar works.
Where would this fix to?
bert
Posted: 2009/1/24 23:34  Updated: 2009/1/24 23:34
 Re: ebay goodies
Hello Master
They certainly do work,the 10mm bar on the back of the KB10 was great.
Did'nt i take a photo of mine?
In simple terms,the loaded side(leaning)pushes up draging the other side with it effectivly pulling the body down on the un loaded side,thus causing the whole rear to remain flatter
Ianey
Posted: 2009/1/24 23:50  Updated: 2009/1/24 23:50
 Re: ebay goodies
Brent is this stuff you have got off ebay? Thats a pretty good collection. Im chasing a rear sway bar as well. Cheers
bert
Posted: 2009/1/24 23:59  Updated: 2009/1/24 23:59
 Re: ebay goodies
The boys said i should have made a jig.I scoffed and said,who would want a KB10 rear bar
Dundee1000
Posted: 2009/1/25 0:45  Updated: 2009/1/25 0:45
 Re: ebay goodies
yea, ok dude, if you really don't want that gear, post it over.. I'll take it... :D
clyons8
Posted: 2009/1/25 0:53  Updated: 2009/1/25 0:53
 Re: ebay goodies
Hello Bert!
Yeah can to take a picture of it all connected, that'd help me undertsand how it works.
If it fixes to the suspension and then to the body wouldn't it foul the whole function of suspension?
datto1000wagon
Posted: 2009/1/25 1:08  Updated: 2009/1/25 1:08
 Re: ebay goodies
ianey the sway bar is made by whiteline it looks old so i dont know if they are even made anymore
and im not even 100% wether its for a 1k i was told it was and the guy gave it to me for free so i wasnt really complaining
dats04
Posted: 2009/1/25 2:37  Updated: 2009/1/25 2:37
 Re: ebay goodies
I WANT THAT GX MANIFOLD!
bert
Posted: 2009/1/25 3:14  Updated: 2009/1/25 3:14
 Re: ebay goodies
Try my albumn Chris
Ianey
Posted: 2009/1/25 4:02  Updated: 2009/1/25 4:02
 Re: ebay goodies
Bert do you know what sway bars are made from?
If I got hold of the correct material and bent up a bar using Brents as a template would it work?
Cheers
steveo
Posted: 2009/1/25 4:49  Updated: 2009/1/25 4:49
 Re: ebay goodies
AWWWWWWW! You always get the goodies! why don't you share?
I was just about to start making a rear swaybar for my B10........
Hey Bert............ you wouldn't want to make me one would you???? or a couple for the matter?
Are they made out of mild steel?
bert
Posted: 2009/1/25 5:17  Updated: 2009/1/25 5:17
 Re: ebay goodies
Sway bars are made from Spring Steel.
Purchase a length(min.2 metres)from Kings or someone similar.
Make yourself a pattern,i normally use heavy welding wire as it's easy to shape.
With an oxy heat your spring steel stock and gradually bend to the shape of your wire pattern,a good vice,gloves,vice grips and another person to assist and hold things also helps in the bending process,you must also heat the "outside" of your bend to avoid cracking the stock.
This all takes a bit of practice,but is very rewarding.
Once you have your shape and it fits where you want it to go,make up your end plates,i normally use 3mm plate with a series of holes for adjustability and "tuning" for more/less stiffness.
Now you have finished,take the bar back to Kings or a spring works and have them heat treat the unit in the oven.
Thats about it for the bar,now just make up your links to go between the bar and the Chassis,a spherical or rose joint at either end is highly desirable.
Cheers
Ianey
Posted: 2009/1/25 6:52  Updated: 2009/1/25 6:52
 Re: ebay goodies
Bert what about the tramp rods on your kb10? How essential are they if you want to go racing?
Also, what thickness do you recommend for a front sway bar?
datto1000wagon
Posted: 2009/1/25 23:33  Updated: 2009/1/25 23:33
 Re: ebay goodies
just took it out and sat it in place on my vb10 fits perfect
