Main : Misc s13, L series speedo gear drives
[<   Previous  406  407  408  409  410  411  412  Next   >]
s13, L series speedo gear drivesPopular
SubmitterhotrocketMore Photos from hotrocket   Last Update2009/1/26 8:29    Tell a friendTell a friend
Hits2567  Comments4    0.00 (0 votes)0.00 (0 votes)
the left is s13 electronic and L series speedo drivers
hotrocket
Posted: 2009/1/26 8:37  Updated: 2009/1/26 8:37
 Re: s13, L series speedo gear drives
the S13 gear is removable from the shaft and is slighty larger, the L series gear is all in one with the shaft,
it still turns but not sure running true to the gear in side the box, changing to run manual speedo cable.....
im not 100% sure if you can get a larger gear
Pendles
Posted: 2009/1/26 11:57  Updated: 2009/1/26 11:57
so you want to put the s13 gear onto the L series drive?
can the L series gear be machined off its sshaft, the simply attach the s13 gear and there's your manual drive.
hotrocket
Posted: 2009/1/26 23:56  Updated: 2009/1/26 23:56
what im going to do is pull out the split pin on the side and checkout the size, i recon there the same shafts size inside just the gearing different, the outer housing looks the same.....
