Main : Misc r31 another angle
[<   Previous  357  358  359  360  361  362  363  Next   >]
r31 another angle
r31 another anglePopular
SubmitterhotrocketMore Photos from hotrocket   Last Update2009/2/3 10:46    Tell a friendTell a friend
Hits1980  Comments7    0.00 (0 votes)0.00 (0 votes)
just a front shot, no rear hangers bolted in a such......
hotrocket
Posted: 2009/2/4 9:05  Updated: 2009/2/4 9:05
 Re: r31 another angle
I looking under my other 1200 coupe to compare and looks to be just on a slight upper angle,
really hard to lay on your back to get the right angle under the car
this rear hasnt got its rear shackles nor the U bolts in,
so the diff can sit straight, once there in it will sit up...at the right angle...im hoping
hotrocket
Posted: 2009/2/4 2:26  Updated: 2009/2/4 2:26
what diagree (angle/pitch) should the diff center sit up
towards the front
PIGDOG
Posted: 2009/2/4 3:45  Updated: 2009/2/4 3:45
i just made mine so when it was it its normal ride height it was parrallel with the gearbox output. so that front and rear unis are at the same angle as each other
hotrocket
Posted: 2009/2/4 4:01  Updated: 2009/2/4 4:01
im pretty sure it be a little of a pitch, wouldnt be much in it i think,
maybe when it on the ground though
mcgee
Posted: 2009/2/4 5:30  Updated: 2009/2/4 5:30
Yeah agree with PIGDOG on this one make sure it is parrallel to the gearbox output. Uni's don't run at a constant angular velocity therefore you need to match the front and rear so they don't fight against each other. I had problems with my hilux install with too much angle difference ~ 8 Degs difference (My stuff up) and I caused noise under coast and diff float, sounded like pinion noise. Fixed now with some wedges to change the diff angle.
There is another method which is a broken back method which means you make the angles opposite. e.g. Gearbox 2 Deg up and Diff 2 Deg up.
High horse power drag cars with leaf springs sometimes allow a couple of degrees for the springs to wind up but for street applications I'd put it the same.
hotrocket
Posted: 2009/2/4 8:59  Updated: 2009/2/4 8:59
why thanku there young mcgee on the heads up....cheers
