Main : Misc assembling front end
[<   Previous  244  245  246  247  248  249  250  Next   >]
assembling front endPopular
SubmitterhotrocketMore Photos from hotrocket   Last Update2009/3/3 9:55    Tell a friendTell a friend
Hits2011  Comments6    0.00 (0 votes)0.00 (0 votes)
starting to come together, polished, chromed, zinced plated and powdercoated...mockup stage to make sure every thing fit nice, the pulled down for paint job on bodie.........
DatsAndy
Posted: 2009/3/3 10:01  Updated: 2009/3/3 10:01
 Re: assembling front end
Cool You using standard control arms and steering arms or stanza. They look standard from here. what are discs and calipers ?
hotrocket
Posted: 2009/3/3 10:04  Updated: 2009/3/3 10:04
yes standard 1200 ute control and steering arm.......
strut complete assy is 1978 120Y drilled & X-drill.......hand cut'n polished calipers
picture does'nt do justice
PIGDOG
Posted: 2009/3/3 10:29  Updated: 2009/3/3 10:29
standard ute stuff which is the same as stanza stuff from the look of the bolts holding the ball joint on and the size of the back of the castor rod
hotrocket
Posted: 2009/3/3 10:47  Updated: 2009/3/3 10:47
thanks mate
look'n at my coupe (12mm bolts) front end it looks lot smaller set up to the ute (17mm bolts) suspension
hotrocket
Posted: 2009/3/3 9:57  Updated: 2009/3/3 9:57
X-member and R31diff off to be powdercoated along with other parts
