Main : Misc LH crossmember
[<   Previous  232  233  234  235  236  237  238  Next   >]
LH crossmember
LH crossmemberPopular
SubmitterK-DOGGMore Photos from K-DOGG   Last Update2009/3/8 11:18    Tell a friendTell a friend
Hits1382  Comments1    0.00 (0 votes)0.00 (0 votes)
its a tight fit between the sump and crossmember. im using the same mounts i cut off the 1200,just makin them a lot shorter,also cut about an inch off the motor mount where it was hanging over the chassis,then welded a new plate for the rubber to sit.
