Main : Misc ignition module
[<   Previous  222  223  224  225  226  227  228  Next   >]
ignition module
ignition modulePopular
SubmitterhotrocketMore Photos from hotrocket   Last Update2009/3/10 11:30    Tell a friendTell a friend
Hits3640  Comments12    0.00 (0 votes)0.00 (0 votes)
theres two types of ca18det loom
LAGWAGON
Posted: 2009/3/11 13:35  Updated: 2009/3/11 13:35
 Re: ignition module
i've had experience with the top set (not plugged in in the pic) not sure on the ones you have plugged in in the pic.
hotrocket
Posted: 2009/3/11 19:03  Updated: 2009/3/11 19:03
 Re: ignition module
exactly,
ive never seen such a loom
hotrocket
Posted: 2009/3/11 0:18  Updated: 2009/3/11 0:18
 Re: ignition module
for you ca18 buff's to answer
hotrocket
Posted: 2009/3/11 7:02  Updated: 2009/3/11 7:02
 Re: ignition module
bump .....guys help its stopping me from firing it up
hotrocket
Posted: 2009/3/11 11:32  Updated: 2009/3/11 11:32
 Re: ignition module
common fella's surely one of you no sumthing!!!!
wheres the guys with ca18det in there 1200's
short-coupe
Posted: 2009/3/11 13:16  Updated: 2009/3/11 13:16
 Re: ignition module
are you sure the other plugs are not for the o2 sensor or the cam packs? i'll try and look at my harness for you on the weekend, you don;t have a CA wiring diagram that you can trace back to the ECU pins?
hotrocket
Posted: 2009/3/11 19:17  Updated: 2009/3/11 19:17
 Re: ignition module
now THATS good question on the o2 sensor, that i have no idea??,
no wiring diagram as such!
i was thinking it maybe from a later model...like 200sx?.......mmm maybe
other that that got me buggered!!!!
crzy_1200_ute
Posted: 2009/3/11 23:56  Updated: 2009/3/11 23:56
 Re: ignition module
it isnt an o2 sensor i can tell u that. as they only came in 1wire and 3wires..
crzy_1200_ute
Posted: 2009/3/12 0:00  Updated: 2009/3/12 0:00
 Re: ignition module
just had a look at mine and i dnt have the buttom two plugged in..
but the top 2 are deff the module you have..
have u got a injector pulse module? small black box
hotrocket
Posted: 2009/3/12 0:27  Updated: 2009/3/12 0:27
 Re: ignition module
CRIKEY il check!....i do have a blackbox BUT it didnt come with the loom, is it bolted on the motor sumwhere?
the top plugs are part of my loom (kev rowley)
the other two plugs go no where been cut.... i say from an old loom sumtime ago.....
ive contacted the guy i got it from hes going to find out
hotrocket
Posted: 2009/3/10 11:44  Updated: 2009/3/10 11:44
 Re: ignition module
close examination there must be a couple different types of CA18det engine looms through the models?
see photo for closer look at the wiring looms the plug may look the same and plugs in ok......its the colors of the wires that concerns me,
the ingition module is a:....(green sticker)22020 60U00 hitachi DIS4-02A..
can anyone sheds sum light on this, is it all right to plug in without any short'n out on me
regards rod.
