Main : Members : PIGDOG finished remote clutch master
[<   Previous  12  13  14  15  16  17  18  Next   >]
finished remote clutch masterPopular
SubmitterPIGDOGMore Photos from PIGDOG   Last Update2009/3/15 0:59    Tell a friendTell a friend
Hits2547  Comments11    0.00 (0 votes)0.00 (0 votes)
some pics of the finished setup
hotrocket
Posted: 2009/3/15 8:07  Updated: 2009/3/15 8:07
 Re: finished remote clutch master
i would of spun the hose the other way so the reservoir poped out near master cylinder,
not bad job
DatsAndy
Posted: 2009/3/15 7:43  Updated: 2009/3/15 7:43
Yeah Nice. Would be interested to know what bits are used here and where did the reservoir end up ?
ANGE
Posted: 2009/3/15 7:59  Updated: 2009/3/15 7:59
looks good, would take care of one big
headache when converting to ca/sr
is that springy looking clamp up to the task
of holding the pressure in the clutch line?
PIGDOG
Posted: 2009/3/15 9:19  Updated: 2009/3/15 9:19
its a ta22 celica master, but most toyota ones are the same
that big hose is just the feed from the res so no pressure in there....same clamp that was on there stock
hose had to go out that way as the res needs to be pretty high up in the engine bay to actually stay higher than the master
its actually much easier to make a setup like this than it is to make one in the engine bay, and end up looking alot neater
all i needed to do was mod the top of the pedal and make up the plate that the master bolts to, then used a toyota hiace brake res with one of the outlets blocked off
heres the pics of the top of the pedal and the bracket
DatsAndy
Posted: 2009/3/15 9:24  Updated: 2009/3/15 9:24
Another question. Whats the hose type fitting from that goes into the master ?
phunkdoktaspok
Posted: 2009/3/15 9:42  Updated: 2009/3/15 9:42
A banjo fitting
PIGDOG
Posted: 2009/3/15 9:44  Updated: 2009/3/15 9:44
yeah its a banjo fitting off a nissan(r33) power steering pump
TUF-110
Posted: 2009/3/15 4:01  Updated: 2009/3/15 4:01
What master cylinder was used?
dattodude
Posted: 2009/3/15 6:51  Updated: 2009/3/15 6:51
looks like an toyota sprinter/ta18 one
Same as mine, but mounted in reverse. Certainly looks simpler than mounting it inside the engine bay.
old_school
Posted: 2009/3/15 10:41  Updated: 2009/3/15 10:41
Good job, simular setup to mine. I used a Ford Econovan Master and a Motorbibe remote resovior mounted in the engine bay.
Its worth the extra effort.
