Main : Mechanical : Body and Interiors Carburetor bore extender
[<   Previous  3016  3017  3018  3019  3020  3021  3022  Next   >]
Carburetor bore extenderPopular
SubmitterddgonzalMore Photos from ddgonzal   Last Update2009/8/18 5:52    Tell a friendTell a friend
Hits1986  Comments6    0.00 (0 votes)0.00 (0 votes)
From a 1978 A14 engine (B210).
revhead001
Posted: 2009/8/20 10:49  Updated: 2009/8/20 10:49
 Re: Carburetor bore extender
It's primary design is to direct the atomised fuel mixture at low engine RPM closer to the bottom of the manifold where the heat exchange is at it's most efficient to prevent fuel from de atomising against the top of the colder inlet manifold. It is mainly for when the engine is cooler to help the engine to run more efficiently.
ROConnor
Posted: 2009/8/20 8:12  Updated: 2009/8/20 8:12
essentualy fources the the gases to travel a further distance, creating higher velocity at lower engine speed's
clyons8
Posted: 2009/8/20 10:25  Updated: 2009/8/20 10:25
Well the mixture isn't traveling much further is it? Seeing as the component is on the inside of the manifold. And if it were to affect the velocity at all I'd say it would be the concept of a smaller tube/volumetric channel that would serve as a jet.
I thought it was to specify direction of the air so as it'd flow more directly over the heated platform.
DatsunSSS
Posted: 2009/8/18 22:24  Updated: 2009/8/18 22:24
the european carb dont have this extender.
What are the effects?
Posted: 2009/8/19 19:06  Updated: 2009/8/19 19:06
Smoother off-idle throttle response.
