Main : Docs : Brochures : Sunny Excellent PB210 Wagon? Malaysia
[<   Previous  19  20  21  22  23  24  25  Next   >]
PB210 Wagon? MalaysiaPopular
SubmitterSharmCosMore Photos from SharmCos   Last Update2009/12/25 4:34    Tell a friendTell a friend
Hits4360  Comments7    0.00 (0 votes)0.00 (0 votes)
Spotted by a friend. PB210 Excellent Wagon? I'm not sure if they did make this. What's the code? VPB210? Reg. number suggest it's a used Jap import..
SharmCos
Posted: 2009/12/28 8:49  Updated: 2009/12/28 8:49
 Re: PB210 Wagon? Malaysia
I don't know, without seeing the engine. Someone might have fitted a complete PB210 panels to the front end. We do have B210 Excellent sedan here, with normal 120Y front end but Excellent tail lamps and A12 engine.
My crashed B210 was an A12 Excellent.
Posted: 2009/12/29 2:28  Updated: 2009/12/29 2:28
Online!
 Re: Hmmm
We do have B210 Excellent sedan here, with ... A12 engine.
That may be as "Excellent" is just a market name and may vary by country. But the "P" in PB210 means a bigger engine than A12, and is a worldwide Nissan model code. So A12 powered B210 is not a PB210. If you observe the engine compartment ID plate you will know for sure.
B210 - A12
HB210 - A14
PB210 - L14 or L16
SharmCos
Posted: 2009/12/29 7:59  Updated: 2009/12/29 7:59
 Re: Hmmm
Yep, knew that. Thanks!
Posted: 2009/12/27 1:32  Updated: 2009/12/27 1:32
Online!
My guess is that someone put the Excellent front sheet metal on a regular VB210.
ROConnor
Posted: 2009/12/27 9:37  Updated: 2009/12/27 9:37
Isent that a regular 120y with some grills rivited to the bonnet?
LittleFireyOne
Posted: 2009/12/27 13:58  Updated: 2009/12/27 13:58
The PB\140-160z had those vents in the bonnet you'll also not the bonnet isn't flat on the front like the normal 120Y. I can't quite make out the seat detail in the pic because the ones I mentioned have different seats aswell.
