Main : Mechanical : Drive Train H150 Diagram
[<   Previous  483  484  485  486  487  488  489  Next   >]
H150 Diagram
H150 DiagramPopular
SubmitterddgonzalMore Photos from ddgonzal   Last Update2010/1/7 6:11    Tell a friendTell a friend
Hits1954  Comments1    0.00 (0 votes)0.00 (0 votes)
1 CARRIER COMP-gear [includes all parts in diagram]
2 WASHER-lock fixing diff bearing cap (4 needed)
3 BOLT-cap fixing diff bearing cap (4)
4 GEAR SET-hypoid
5 BOLT-drive gear (8)
6 STRAP-lock bolt (4)
7 CASE-diff
8 GEAR-side diff bevel (2)
9 PINION-mate diff bevel (2)
10 WASHER-thrust side gear (2) [various thicknesses avail.]
11 WASHER-thrust pinion mate (2)
12 SHAFT-pinion mate
13 PIN-lock pinion shaft
14 BEARING ASS'Y-diff side (2)
15 SHIM-adjusting side bearing [various thicknesses avail.]
16 BEARING ASS'Y-drive pinion, rear
17 BEARING ASS'Y-drive pinion, front
18 SPACER-drive pinion
19 WASHER-adjusting drive pinion [many thicknesses avail.]
20 SEAL-oil front
21 FLANGE ASS'Y-comp pinion
22 NUT-drive pinion
23 GASKET-gear carrier
24 BOLT (8)
