Main : Mechanical Timing cover damage 01
[<   Previous  246  247  248  249  250  251  252  Next   >]
Timing cover damage 01Popular
SubmitterLittleFireyOneMore Photos from LittleFireyOne   Last Update2010/1/18 0:23    Tell a friendTell a friend
Hits2204  Comments1    0.00 (0 votes)0.00 (0 votes)
the other timing cover I could use. minimal corrosion but damage from foreign (< that spelling makes no sense!) particles or the water pump blades in the cooling system
Posted: 2015/5/5 23:56  Updated: 2015/5/5 23:56
 Re: Timing cover damage 01
Those pits are no problem. It looks like it happened long ago, and since has been washed clean.
I suspect electrolysis from running plain water, or maybe high-RPM cavitation. Using a stock water pump (with the cast impeller) is said to prevent cavitation -- the stamped impeller of cheap water pumps allows shock waves to build up at over 5000 rpm. Dunno if that actually occurs or not.
